Problem with the RTX 3060, could anyone help me?
  • March 26, 2024
  • 8 replies
  • 566 views
Since I changed video cards, my photoshop has been giving me this type of display error, I try to zoom or use the brush tool, text tool or some other tool and this always happens, how can I solve it? I already tried to activate support for old GPUs in the settings but it didn't work very well, (besides the 3060 isn't that old, right? 🤷‍♂)
Could anyone help me please?
@Ged_Traynor  Unfortunately, enabling this option didn't solve the problem, but I'm having this problem in previous versions too, could it be because I switched from AMD to Nvidia? Any residue from the previous board's drivers?
Ged_Traynor
@rafael.laerte there's nothing wrong with the GPU you have, and it should work without issue in Photoshop, there are a lot of people reporting the same issue as you, you could try enabling this option in preferences and restarting Photoshop to see if it helps, if not try reverting back to version 25.5.1
@Ged_Traynor  I finished doing a clean installation of the drive, but the same error persists
Ged_Traynor
@rafael.laerte when installing, go to custom > advanced and then select perform a clean installation
I currently use the studio version, but I saw that a new version was released, I will install it to see if the problem is resolved
Ged_Traynor
@rafael.laerte system info looks fine, do you use the Nvidia Studio and Game Ready driver, Adobe recommends the Studio version
Versão Adobe Photoshop: 25.6.0 20240312.r.433 2bfcbf1 x64
Número de lançamentos: 80
Sistema Operacional: Windows 10 64-bits
Versão: 10 10.0.19045.4170
Arquitetura do sistema: Intel Família CPU:6, Modelo:15, Etapa:2 cp, MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1 e SSE4.2, AVX, AVX2, HyperThreading
Contagem de processadores físicos: 12
Contagem de processadores lógicos: 24
Velocidade do processador: 2494 MHz
Memória interna: 32612 MB
Memória livre: 20905 MB
Memória disponível para Photoshop: 25065 MB
Memória usada pelo Photoshop: 70 %
Manipulador de falhas: Adobe
DCX Version: 7.13.2
SAM SDK Version: 7.7.0-fio
ACP.local Status:
- SDK Version: 3.4.0
- Core Sync Status: Reachable and compatible
- Core Sync Running: 7.1.1.1
- Min Core Sync Required: 4.3.66.28
Cliente de edição ao vivo versão SDK: 4.0.4
Open Color IO versão: 2.3.2
Biblioteca versão C2PA: adobe_c2pa/0.7.6-2 c2pa-rs/0.25.2-patch
Versão NGL: 1.37.0.8
Lousa: Desativado.
Renderizador D3D3D12Warp: Desativado.
Tela de lona: Ativado.
Camadas do alias: Desativado.
Highbeam: Ativado.
HUION Wintab 1.1
Spec Version 1.1
Impl Version 1.0
Num Devices 1
Tamanho de ladrilhos de cache: 1024K
Níveis do cache de imagem: 4
Visualização da fonte: Média
Versão HarfBuzz: 7.3.0
TextEngine: mecanismo de texto unificado
======= GPU
API nativo estável: Verdadeiro
API OpenGL estável: Verdadeiro
API OpenCL estável: Verdadeiro
GPUDeny: 0
GPUForce: 0
useGPU: 1
useOpenCL: 1
isGPUCapable: 1
GPUName: NVIDIA GeForce RTX 3060
GPUVendor: NVIDIA
IsNativeGPUCapable: 1
IsOpenGLGPUCapable: 1
IsOpenCLGPUCapable: 1
HasSufficientRAM: 1
GPU accessible RAM: 12,115 MB
Required GPU accessible RAM: 1,500 MB
UseGraphicsProcessorChecked: 1
UseOpenCLChecked: 1
Windows remote desktop: 0
Windows available feature level: 12.1
Windows required feature level: 12.0
Windows has required feature level: 1
Vídeo: 1
Os limites de exibição são: (0, 0) -> (2560, 1080)
Escala de exibição: 1
Tipo de exibição: SDR
------- Sniffer output
[0 ms]
Launch GPUSnifferThread
[1 ms]
Start RunAllAPIs
[1 ms]
"C:\Program Files\Adobe\Adobe Photoshop 2024\sniffer.exe" -baseTimeMS=554010428 -comment=Photoshop Version: Adobe Photoshop 25.6.0 20240312.r.433 2bfcbf1 x64
[1 ms]
Start GetSnifferResult
[1479 ms]
Start sniffer 2024-03-26 09:27:04
# Photoshop Version: Adobe Photoshop 25.6.0 20240312.r.433 2bfcbf1 x64
C:\Program Files\Adobe\Adobe Photoshop 2024\sniffer.exe -baseTimeMS=554010428 -comment=Photoshop Version: Adobe Photoshop 25.6.0 20240312.r.433 2bfcbf1 x64
{99 ms}
Start platform native
# displays: 1
Display 0
Display: \\.\DISPLAY1
Main: TRUE
Built in: FALSE
Stereo: FALSE
Bounds: (0, 0) -> (2,560, 1,080)
Dimensions: (2,560 1,080)
Display scale: 1
Physical size: (0 0)
Pixel size: (0 0)
Dynamic range: (0 1)
Potential dynamic range: (0 1)
Reference dynamic range: (0 1)
Attached Device: (DeviceID name=NVIDIA GeForce RTX 3060 index=0)
# devices: 1
Device 0
Preferred: TRUE
Power Envelope: UNKNOWN
Attachment: UNKNOWN
# attached displays: 1
\\.\DISPLAY1
VRAM: 12,115 MB
Dedicated System RAM: 0 MB
Shared System RAM: 17,098 MB
API version: 12.0 (12.0)
Device version: 12.0 (12.0)
Vendor name: NVIDIA
Driver date: 2024-01-18 000000.000000-000
Driver age: 2 months
Driver version: 31.0.15.5123
Supports UMA: UNSUPPORTED
D3D-ID: 9476
End platform native
{438 ms}
{438 ms}
Start platform OpenGL
# displays: 1
Display 0
Main: TRUE
Built in: FALSE
Stereo: FALSE
Display scale: 1
Pixel size: (0 0)
Attached Device: (DeviceID name=NVIDIA GeForce RTX 3060/PCIe/SSE2 index=0)
# devices: 1
Device 0
Name: NVIDIA GeForce RTX 3060/PCIe/SSE2
Preferred: TRUE
Power Envelope: INTEGRATED
Attachment: UNKNOWN
\\.\DISPLAY1
GPU accessible RAM: 12,703 MB
VRAM: 12,703 MB
API version: 2.1 (2.1.2 NVIDIA 551.23)
Device version: 2.1 (2.1.2 NVIDIA 551.23)
Vendor name: NVIDIA
GLSL version: 1.20 (1.20 NVIDIA via Cg compiler)
End platform OpenGL
{941 ms}
{941 ms}
Start platform OpenCL
# displays: 0
# devices: 1
Device 0
Preferred: TRUE
Power Envelope: DISCRETE
Attachment: UNKNOWN
# attached displays: 0
GPU accessible RAM: 12,884 MB
VRAM: 12,884 MB
Shared System RAM: 0 MB
API version: 3.0 (OpenCL 3.0 CUDA)
Device version: 3.0 (OpenCL 3.0 CUDA)
Vendor name: NVIDIA
Driver date: UNKNOWN
Driver age: UNKNOWN
Driver version: UNKNOWN
Bandwidth: 318 GB / s
Compute score: 2,018.41
Device name string: NVIDIA GeForce RTX 3060
Device vendor string: NVIDIA Corporation
Platform name string: NVIDIA CUDA
Platform vendor string: NVIDIA Corporation
End platform OpenCL
{1368 ms}
Exit code kExitNormal
End sniffer 2024-03-26 09:27:05
[kStatusNormal, kExitNormal]
[1479 ms]
Finish RunAllAPIs
[1489 ms]
Finish GetSnifferResult
======= GPU
Tipo de licença: Assinatura
Número de série: 90970531720414207567
GUIDBucket:
Composite Core GPU (comp_core_gpu): on
Composite Core Threads (MultithreadedCompositing): on
Composite Core UI (comp_core_ui): off
Composite Core Feature Prefs (CompCoreFeaturePrefs): off
Document Graph (DocumentGraph): off
Pasta do aplicativo: C:\Program Files\Adobe\Adobe Photoshop 2024\
Demarcador de arquivo temporário: C:\Users\rafae\AppData\Local\Temp\
O rascunho do Photoshop tem E/S assíncrona ativado
Volume de trabalho(s):
Inicialização, 476,3G, 88,0G livre
Pasta de plug-ins necessários: C:\Program Files\Adobe\Adobe Photoshop 2024\Required\Plug-ins\
Pasta de plug-ins principais: C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\
Componentes instalados:
ACE.dll ACE 2024/01/20-13:45:37 79.f53cec6 79.f53cec6
act_tracing.dll Copyright (c) 2021 Adobe. All Rights Reserved 1.0.58
AdobeLinguistic.dll Adobe Linguisitc Library 2d5dab2
AdobeOwl.dll Adobe Owl 5.5.0
AdobePDFL.dll PDFL 2024/01/20-13:45:37 79.fafc444 79.fafc444
AdobePIP.dll Adobe Product Improvement Program 8.2.0.16
AdobeSVGAGM.dll AdobeSVGAGM 79.3ef291b 79.3ef291b
AdobeXMP.dll Adobe XMP Core 2023/12/13-05:06:49 79.dba3da3 79.dba3da3
AdobeXMPFiles.dll Adobe XMP Files 2023/12/13-05:06:49 79.dba3da3 79.dba3da3
AdobeXMPScript.dll Adobe XMP Script 2023/12/13-05:06:49 79.dba3da3 79.dba3da3
AGM.dll AGM 2024/01/20-13:45:37 79.f53cec6 79.f53cec6
AID.dll AID DLL 1.0.0.58
AIDE.dll AIDE 2024/01/15-13:56:09 79.dc35314 79.dc35314
aifm.dll AIFM 1.0 23.68434
AILib.dll Adobe Illustrator 2024 28.0.0
aiport.dll AIPort 1.0 23.68434
ARE.dll ARE 2024/01/20-13:45:37 79.f53cec6 79.f53cec6
AXE8SharedExpat.dll AXE8SharedExpat 2023/12/05-19:10:14 79.c9ba055 79.c9ba055
AXEDOMCore.dll AXEDOMCore 2023/12/05-19:10:14 79.c9ba055 79.c9ba055
BIB.dll BIB 2024/01/20-13:45:37 79.f53cec6 79.f53cec6
BIBUtils.dll BIBUtils 2024/01/20-13:45:37 79.f53cec6 79.f53cec6
boost_chrono.dll photoshopdva 22.0.0
boost_date_time.dll photoshopdva 22.0.0
boost_filesystem.dll photoshopdva 22.0.0
boost_regex.dll photoshopdva 22.0.0
boost_system.dll photoshopdva 22.0.0
boost_threads.dll photoshopdva 22.0.0
CoolType.dll CoolType 2024/01/20-13:45:37 79.f53cec6 79.f53cec6
CRClient.dll Adobe Crash Reporter Client DLL 14.0.0.202310260823_2e78abe
DirectML.dll DirectML Redistributable Library 1.10.1+230125-1155.1.dml-1.10.177341d
dnssd.dll Bonjour 3,0,0,2
dvaaccelerate.dll photoshopdva 22.0.0
dvaappsupport.dll photoshopdva 22.0.0
dvaaudiodevice.dll photoshopdva 22.0.0
dvaaudiodsp.dll photoshopdva 22.0.0
dvacore.dll photoshopdva 22.0.0
dvacrashhandler.dll Adobe Audition CC 2017 10.0.0
dvamarshal.dll photoshopdva 22.0.0
dvamediatypes.dll photoshopdva 22.0.0
dvametadata.dll photoshopdva 22.0.0
dvametadataapi.dll photoshopdva 22.0.0
dvametadataUI.dll photoshopdva 22.0.0
dvanet.dll photoshopdva 22.0.0
dvaplayer.dll photoshopdva 22.0.0
dvascripting.dll photoshopdva 22.0.0
dvatransport.dll photoshopdva 22.0.0
dvaui.dll photoshopdva 22.0.0
dvavulcansupport.dll photoshopdva 22.0.0
dynamic-torqnative.dll Unified Extensibility Platform uxp-7.4.1-release
dynamiclink.dll photoshopdva 22.0.0
ExtendScript.dll ExtendScript 2022/08/18-12:50:45 82.4 82.4
filterport.dll FilterPort 1.1 O
icucnv73.dll International Components for Unicode Build 14.0.1.04ee3a5
icuin73.dll International Components for Unicode Build 14.0.1.04ee3a5
icuuc73.dll International Components for Unicode Build 14.0.1.04ee3a5
ippcc.dll ippCC. Intel(R) Integrated Performance Primitives. Color Conversion. 2021.6 (r0xbffe3c5b)
ippcck0.dll ippCC. Intel(R) Integrated Performance Primitives. Color Conversion. 2021.6 (r0xbffe3c5b)
ippccl9.dll ippCC. Intel(R) Integrated Performance Primitives. Color Conversion. 2021.6 (r0xbffe3c5b)
ippccy8.dll ippCC. Intel(R) Integrated Performance Primitives. Color Conversion. 2021.6 (r0xbffe3c5b)
ippcore.dll core. Intel(R) Integrated Performance Primitives. Core Library. 2021.6 (r0xbffe3c5b)
ippcv.dll ippCV. Intel(R) Integrated Performance Primitives. Computer Vision. 2021.6 (r0xbffe3c5b)
ippcvk0.dll ippCV. Intel(R) Integrated Performance Primitives. Computer Vision. 2021.6 (r0xbffe3c5b)
ippcvl9.dll ippCV. Intel(R) Integrated Performance Primitives. Computer Vision. 2021.6 (r0xbffe3c5b)
ippcvy8.dll ippCV. Intel(R) Integrated Performance Primitives. Computer Vision. 2021.6 (r0xbffe3c5b)
ippi.dll ippIP. Intel(R) Integrated Performance Primitives. Image Processing. 2021.6 (r0xbffe3c5b)
ippik0.dll ippIP. Intel(R) Integrated Performance Primitives. Image Processing. 2021.6 (r0xbffe3c5b)
ippil9.dll ippIP. Intel(R) Integrated Performance Primitives. Image Processing. 2021.6 (r0xbffe3c5b)
ippiy8.dll ippIP. Intel(R) Integrated Performance Primitives. Image Processing. 2021.6 (r0xbffe3c5b)
ipps.dll ippSP. Intel(R) Integrated Performance Primitives. Signal Processing. 2021.6 (r0xbffe3c5b)
ippsk0.dll ippSP. Intel(R) Integrated Performance Primitives. Signal Processing. 2021.6 (r0xbffe3c5b)
ippsl9.dll ippSP. Intel(R) Integrated Performance Primitives. Signal Processing. 2021.6 (r0xbffe3c5b)
ippsy8.dll ippSP. Intel(R) Integrated Performance Primitives. Signal Processing. 2021.6 (r0xbffe3c5b)
ippvm.dll ippVM. Intel(R) Integrated Performance Primitives. Vector Math. 2021.6 (r0xbffe3c5b)
ippvmk0.dll ippVM. Intel(R) Integrated Performance Primitives. Vector Math. 2021.6 (r0xbffe3c5b)
ippvml9.dll ippVM. Intel(R) Integrated Performance Primitives. Vector Math. 2021.6 (r0xbffe3c5b)
ippvmy8.dll ippVM. Intel(R) Integrated Performance Primitives. Vector Math. 2021.6 (r0xbffe3c5b)
JP2KLib.dll JP2KLib 2024/01/12-09:47:24 79.9bc0193 79.9bc0193
libeay32.dll The OpenSSL Toolkit 1.0.2zg
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(R) C/C++/Fortran Compiler Mainline
libzip.dll photoshopdva 22.0.0
LogSession.dll LogSession 8.2.0.16
mediacoreif.dll photoshopdva 22.0.0
Microsoft.AI.MachineLearning.dll Microsoft® Windows® Operating System 1.14.20230410.1.429e1e3
mkl_avx2.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_avx512.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_core.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_def.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_mc3.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_sequential.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_vml_avx2.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_vml_avx512.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_vml_def.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_vml_mc3.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
MPS.dll MPS 2023/12/11-10:35:54 79.91918d2 79.91918d2
onnxruntime.dll Microsoft® Windows® Operating System 1.14.20230410.1.429e1e3
opencv_world452.dll OpenCV library 4.5.2
pdfport.dll PDFPort 2020/11/19-11:34:27 79.625377 79.625377
Plugin.dll Adobe Photoshop 2024 25.6
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 11.5.2
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 11.5.2.130
PSCloud.dll 1.0.0.1
PSRes.dll Adobe Photoshop 2024 25.6
PSViews.dll Adobe Photoshop 2024 25.6
ScCore.dll ScCore 2022/08/18-12:50:45 82.4 82.4
ssleay32.dll The OpenSSL Toolkit 1.0.2zg
SVGRE.dll SVGRE 79.73849cc 79.73849cc
svml_dispmd.dll Intel(R) C/C++/Fortran Compiler Mainline
VulcanControl.dll Vulcan Application Control Library 7.2.0.34
VulcanMessage5.dll Vulcan Message Library 7.2.0.34
WinRTSupport.dll Adobe Photoshop Windows RT Support 1.0.1.0
WRServices.dll WRServices Build 18.0.0.788c4ff 18.0.0.788c4ff
Plataforma de extensibilidade unificada uxp-7.4.1-release
UPIC 2.6.0
Plug-ins necessários:
Afresco 25.6 - do arquivo “Filter Gallery.8bf”
Aquarela 25.6 - do arquivo “Filter Gallery.8bf”
Arestas Acentuadas 25.6 - do arquivo “Filter Gallery.8bf”
Arestas Brilhantes 25.6 - do arquivo “Filter Gallery.8bf”
Arestas Posterizadas 25.6 - do arquivo “Filter Gallery.8bf”
Arestas Rasgadas 25.6 - do arquivo “Filter Gallery.8bf”
Assimetria 25.6 - do arquivo “statistics.8ba”
Baixo-Relevo 25.6 - do arquivo “Filter Gallery.8bf”
Bastão de Borrar 25.6 - do arquivo “Filter Gallery.8bf”
Bico de Pena 25.6 - do arquivo “Filter Gallery.8bf”
BMP 25.6 - do arquivo “Standard MultiPlugin.8bf”
Bordado 25.6 - do arquivo “Filter Gallery.8bf”
Brilho Difuso 25.6 - do arquivo “Filter Gallery.8bf”
Camera Raw 16.2 - do arquivo “Camera Raw.8bi”
Carvão 25.6 - do arquivo “Filter Gallery.8bf”
Centro da Medida 25.6 - do arquivo “MeasurementCore.8me”
Cineon 25.6 - do arquivo “Cineon.8bi”
Cisalhamento 25.6 - do arquivo “Standard MultiPlugin.8bf”
Coordenadas Polares 25.6 - do arquivo “Standard MultiPlugin.8bf”
Cores NTSC 25.6 - do arquivo “NTSC Colors.8bf”
Correção de Lente 25.6 - do arquivo “Lens Correction.8bf”
Cortar e corrigir fotos 25.6 - do arquivo “CropPhotosAuto.8li”
Craquelé 25.6 - do arquivo “Filter Gallery.8bf”
Crayon Conté 25.6 - do arquivo “Filter Gallery.8bf”
Cristalizar 25.6 - do arquivo “Standard MultiPlugin.8bf”
Cromo 25.6 - do arquivo “Filter Gallery.8bf”
Curtose 25.6 - do arquivo “statistics.8ba”
Demarcadores para o Illustrator 25.6 - do arquivo “Standard MultiPlugin.8bf”
Desentrelaçamento 25.6 - do arquivo “Standard MultiPlugin.8bf”
Desfoque de Lente 25.6 - do arquivo “Lens Blur.8bf”
Desfoque Inteligente 25.6 - do arquivo “Standard MultiPlugin.8bf”
Desfoque Radial 25.6 - do arquivo “Standard MultiPlugin.8bf”
Desvio Padrão 25.6 - do arquivo “statistics.8ba”
Dicom 25.6 - do arquivo “Dicom.8bi”
Dissolver 25.6 - do arquivo “Liquify.8bf”
Entropia 25.6 - do arquivo “statistics.8ba”
Esferização 25.6 - do arquivo “Standard MultiPlugin.8bf”
Espátula 25.6 - do arquivo “Filter Gallery.8bf”
Esponja 25.6 - do arquivo “Filter Gallery.8bf”
Estampa 25.6 - do arquivo “Filter Gallery.8bf”
Exportar as tabelas de pesquisa de cores 25.6 - do arquivo “Export3DLUT.8be”
Extrusão 25.6 - do arquivo “Standard MultiPlugin.8bf”
Fibras 25.6 - do arquivo “Standard MultiPlugin.8bf”
Filtro Camera Raw 16.2 - do arquivo “Camera Raw.8bi”
Filtro Cortar e Corrigir Fotos 25.6 - do arquivo “Standard MultiPlugin.8bf”
Filtro do Pacote de Figuras 25.6 - do arquivo “ChannelPort.8bf”
Formato IFF 25.6 - do arquivo “Standard MultiPlugin.8bf”
Foto Granulada 25.6 - do arquivo “Filter Gallery.8bf”
Fotocópia 25.6 - do arquivo “Filter Gallery.8bf”
Galeria de filtros 25.6 - do arquivo “Filter Gallery.8bf”
Gesso 25.6 - do arquivo “Filter Gallery.8bf”
Giz e Carvão 25.6 - do arquivo “Filter Gallery.8bf”
Grande angular adaptável 25.6 - do arquivo “Adaptive Wide Angle.8bf”
Granulado 25.6 - do arquivo “Filter Gallery.8bf”
Hachura 25.6 - do arquivo “Filter Gallery.8bf”
Halide Bottlenecks 25.6 - do arquivo “HalideBottlenecks.8bx”
HDRMergeUI 25.6 - do arquivo “HDRMergeUI.8bf”
HSB/HSL 25.6 - do arquivo “Standard MultiPlugin.8bf”
Intervalo 25.6 - do arquivo “statistics.8ba”
JPEG 2000 25.6 - do arquivo “JPEG2000.8bi”
Ladrilhos 25.6 - do arquivo “Standard MultiPlugin.8bf”
Ladrilhos do Mosaico 25.6 - do arquivo “Filter Gallery.8bf”
Lápis de Cor 25.6 - do arquivo “Filter Gallery.8bf”
Marola 25.6 - do arquivo “Filter Gallery.8bf”
Matlab Operation 25.6 - do arquivo “ChannelPort.8bf”
Matriz de Meio-Tom 25.6 - do arquivo “Filter Gallery.8bf”
Máximo 25.6 - do arquivo “statistics.8ba”
Média 25.6 - do arquivo “Average.8bf”
Mediana 25.6 - do arquivo “statistics.8ba”
Meia-Tinta 25.6 - do arquivo “Standard MultiPlugin.8bf”
Meio-Tom em Cores 25.6 - do arquivo “Standard MultiPlugin.8bf”
Mesclagem 25.6 - do arquivo “Standard MultiPlugin.8bf”
Mínimo 25.6 - do arquivo “statistics.8ba”
Néon 25.6 - do arquivo “Filter Gallery.8bf”
Nuvens 25.6 - do arquivo “Clouds.8bf”
Nuvens por Diferença 25.6 - do arquivo “Clouds.8bf”
Ondas 25.6 - do arquivo “Standard MultiPlugin.8bf”
Ondulação 25.6 - do arquivo “Standard MultiPlugin.8bf”
OpenEXR 25.6 - do arquivo “Standard MultiPlugin.8bf”
Papel de Carta 25.6 - do arquivo “Filter Gallery.8bf”
Papel Molhado 25.6 - do arquivo “Filter Gallery.8bf”
Parametric Filter NO VERSION - do arquivo “MaterialFilter.8bf”
Pastéis Ásperos 25.6 - do arquivo “Filter Gallery.8bf”
PCX 25.6 - do arquivo “PCX.8bi”
Pincel a Seco 25.6 - do arquivo “Filter Gallery.8bf”
Pixar 25.6 - do arquivo “Pixar.8bi”
Plastificação 25.6 - do arquivo “Filter Gallery.8bf”
Pontilhar 25.6 - do arquivo “Standard MultiPlugin.8bf”
Ponto de Fuga 25.6 - do arquivo “VanishingPoint.8bf”
Portable Bit Map 25.6 - do arquivo “PBM.8bi”
Radiance 25.6 - do arquivo “Radiance.8bi”
Rastro da Tinta 25.6 - do arquivo “Filter Gallery.8bf”
Recorte de Arestas 25.6 - do arquivo “Filter Gallery.8bf”
Redemoinho 25.6 - do arquivo “Standard MultiPlugin.8bf”
Reflexo de Flash 25.6 - do arquivo “Standard MultiPlugin.8bf”
Renderizar a grade de pesquisa de cores 25.6 - do arquivo “Export3DLUT.8be”
Respingo 25.6 - do arquivo “Filter Gallery.8bf”
Reticulação 25.6 - do arquivo “Filter Gallery.8bf”
Rotinas FastCore 25.6 - do arquivo “FastCore.8bx”
Rotinas MMXCore 25.6 - do arquivo “MMXCore.8bx”
Salvar para Web 25.6 - do arquivo “Save for Web.8be”
Solarização 25.6 - do arquivo “Solarize.8bf”
Somatória 25.6 - do arquivo “statistics.8ba”
SP Substance Suite NO VERSION - do arquivo “MaterialSuite.8li”
Sucção 25.6 - do arquivo “Standard MultiPlugin.8bf”
Sumi-e 25.6 - do arquivo “Filter Gallery.8bf”
Suporte a Multiprocessamento 25.6 - do arquivo “MultiProcessor Support.8bx”
Suporte para Scripts 25.6 - do arquivo “ScriptingSupport.8li”
Suporte WIA 25.6 - do arquivo “WIASupport.8li”
Targa 25.6 - do arquivo “Standard MultiPlugin.8bf”
Texturizador 25.6 - do arquivo “Filter Gallery.8bf”
Tinta-Base 25.6 - do arquivo “Filter Gallery.8bf”
Toques de Tinta 25.6 - do arquivo “Filter Gallery.8bf”
Traçado Angular 25.6 - do arquivo “Filter Gallery.8bf”
Traçado Borrifado 25.6 - do arquivo “Filter Gallery.8bf”
Traçado Escuro 25.6 - do arquivo “Filter Gallery.8bf”
Valor médio 25.6 - do arquivo “statistics.8ba”
Variância 25.6 - do arquivo “statistics.8ba”
Vento 25.6 - do arquivo “Standard MultiPlugin.8bf”
Vidro 25.6 - do arquivo “Filter Gallery.8bf”
Vitral 25.6 - do arquivo “Filter Gallery.8bf”
WBMP 25.6 - do arquivo “WBMP.8bi”
Ziguezague 25.6 - do arquivo “Standard MultiPlugin.8bf”
Plug-ins opcionais e de terceiros: NENHUM
Plug-ins duplicados e desativados: NENHUM
Plug-ins com falha no carregamento: NENHUM
Plataforma de extensibilidade unificada - Extensões:
Home Screen (carregado) 7.4.0.15 - do arquivo "C:\Program Files\Common Files\Adobe/UXP/Extensions\com.adobe.ccx.start-7.4.0\"
CmdN: 1.19.26
UAB: 2.18.0-4
Carregado em: 448 ms - impacto no momento de inicialização: 79 ms
ccx-timeline (Preparado) 3.1.12.0 - do arquivo "Pasta necessária"
CCX Commenting UXP Webview (carregado) 30.7.0.0 - do arquivo "Pasta necessária"
Carregado em: 8442 ms - impacto no momento de inicialização: 0 ms
CCX Sharesheet UXP (Preparado) 30.4.1.0 - do arquivo "Pasta necessária"
Content Credentials (carregado) 0.42.17.0 - do arquivo "Pasta necessária"
Carregado em: 7453 ms - impacto no momento de inicialização: 1 ms
CC Libraries Panel (Preparado) 4.4.461.0 - do arquivo "C:\Program Files\Common Files\Adobe/CEP/Extensions\CC_LIBRARIES_PANEL_EXTENSION_4_4_461\"
CAPTURE: 2.0.41 STOCK: 4.2.2
In app notifications (carregado) 2.0.7.0 - do arquivo "Pasta necessária"
Carregado em: 8444 ms - impacto no momento de inicialização: 0 ms
Filtro paramétrico (carregado) 0.1.8.0 - do arquivo "Pasta necessária"
Carregado em: 8447 ms - impacto no momento de inicialização: 0 ms
Photoshop Adjustments Panel (carregado) 2.1.16.0 - do arquivo "Pasta necessária"
Carregado em: 8450 ms - impacto no momento de inicialização: 1 ms
Photoshop UXP Export-As (carregado) 5.8.37.0 - do arquivo "Pasta necessária"
Carregado em: 1808881 ms - impacto no momento de inicialização: 0 ms
Photoshop In App Messaging (carregado) 4.3.10.0 - do arquivo "Pasta necessária"
Carregado em: 8452 ms - impacto no momento de inicialização: 0 ms
Information Alert (Preparado) 0.5.0.0 - do arquivo "Pasta necessária"
Photoshop Selection Feedback (Preparado) 0.5.0.0 - do arquivo "Pasta necessária"
Plugins Panel (Preparado) 1.4.3.0 - do arquivo "Pasta necessária"
IC popup message (carregado) 1.0.0.0
Carregado em: 7458 ms - impacto no momento de inicialização: 0 ms
Multilayer Protection (carregado) 1.0.0.0
Carregado em: 7461 ms - impacto no momento de inicialização: 0 ms
Discover Panel (carregado) 2402.93.0.17 - do arquivo "Pasta necessária"
Carregado em: 8454 ms - impacto no momento de inicialização: 0 ms
Neural Filters (Registrado) 1.15.0.100 - do arquivo "Pasta necessária"
Tempo de varredura: 0 ms - Entradas: 27
Extensões:
Bibliotecas 1.0.0 - do arquivo “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_4_4_461\index.html”
com.adobe.stock.panel.licensing-embedded 4.0.35 - do arquivo “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_4_4_461\extensions\stock-panel-licensing\index.html”
com.adobe.capture.extension 2.0.41 - do arquivo “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_4_4_461\extensions\capture\capture.html”
Exportar como 4.8.15 - do arquivo “C:\Program Files\Adobe\Adobe Photoshop 2024\Required\CEP\extensions\com.adobe.photoshop.crema\index.html”
com.adobe.cclibraries.manager 1.0.0 - do arquivo “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_4_4_461\manager.html”
Dispositivos TWAIN instalados: NENHUM
Ged_Traynor
@rafael.laerte can you post your Photoshop system info, in Photoshop go to Help > System Info, hit the copy button and paste the entire thing into this thread
