Problems copy and pasting RGB channels and layers
  • May 4, 2019
  • 5 replies
  • 9643 views
I am using a MacBook pro running "mojave" 10.14.4 and using photoshop cc2019 20.0.4 and I can't copy paste channels or layers.  I first tried loading the 4 channels, red, green, blue and luminance and then I opened a new document.  I then did a command A on each channel and tried to paste to its selected channel.  No go!.  In fact when I copy all the paste command is grayed out.  I then selected one of the RGB files and right clicked the the channels and selected merge channels and this allowed me to use the rgb channels in a pic but I could not add the luminance channel as a layer.  Very frustrating.  Any suggestions would be appreciated.
Joe in Mobile
    Correct answer Francesco Della Peruta
    Have you check the number of bit per channel? Have you tried to reset photoshop preferences?
    Please take a look here:
    Copy and Paste a channel in Photoshop CC
    Having this issue in Photoshop 2021. None of the suggestions in this thread work for me. I'm trying to copy the Green channel onto Red and Blue and the 'paste' option is greyed out.
    D Fosse
    I've always just used ctrl+C and ctrl+V for this. Does that work?
    It actually hasn't occurred to me to look for a Paste command, so I don't even know if that works.
    If anyone is still having this problem in 2022 try switching to 16 bits and then switching back.
    I really appreciate everyone' s help.  As usual it was a user issue.   I would to the command-a but not the command-c.  I kept thinking that the select all was copying it.  Sheesh!  The light came on and I saw the error of my ways.  Thanks again everyone.  Let the astrophotography torment begin anew.
    Joe in Mobile
    Daniel E Lane
    What are you trying to achieve with this? Just asking to better be able to help you get to the final goal...
    i am shooting astro pics in mono with RGB and Lum filters.  Trying to combine them to edit them.
    Joe in Mobile
    Bojan Živković11378569
    Everything works fine on Win. I tried a couple of ways and all of them work as expected. You are missing something. Here are the steps:
    • Select proper layer in the Layers panel
    • Open Channels panel and click one of the three channels: Red, Green or Blue. Other channels will be hidden, only one channel should be visible
    • Use Select > Select All then Copy and Paste commands
    Method number two:
    • Select - click on it - channel which you want to duplicate
    • Right click on channel and choose: Duplicate Channel
    • In the Duplicate Channel dialog you can give a name to duplicated instance and also to choose document in which you want to duplicate channel in the Destination section.
