Pergunta
PS 2020 brush lag and auto connecting straight line problem
  • July 9, 2020
  • 3 respostas
  • 544 Visualizações
Hi. I have been using PS 2020 on my MacBook Pro for quite a long time. But this problem has came up more recently.
When ever I use "Option" key in Brush tool as a quick access to the Straw tool, it auto-connects as a straight line as I go back to Brush tool. This also happened when I change to another brush tool in Tool Prest and go back onto the Canvas. Apparently there is kind of brush lag, but also the straight line problem.
I'm on macOS 10.14.3 and PS 2020  21.0.1. with a wacom tablet. If any one could help me I would be very appreciate! It really affects my painting efficiency.
Este tópico foi fechado para respostas.
3 Respostas
leds2097726
This has been a longstanding problem in Photoshop, we have been complaining about it for over five years. Adobe blame Apple and Wacom and refuse to fix it. None of the remedies posted by anyone here will work so don't waste your time.
: ( Some posts did help me to solve problems in the past but there are still more and more occuring...
Otherwise try to reset photoshop preferences
Ok I will try it, thank you!
