Registration code CS3 - help help help urgent
  • March 27, 2020
  • 156 views
hi
i need help to find my authorization code for my photshop cs3.
as i have my serial number & activation code.
thanks in advance.
davescm
CS3 can no longer be activated as the activation servers have been shut down. Adobe customer care cannot help you with that.
Dave
c.pfaffenbichler
If you are trying to install CS3 on a new computer you might be out of luck.
Barb Binder
Contact Adobe Customer Care: https://helpx.adobe.com/contact.html
~Barb
