Required Billboard/Hoarding Help !!
Hello, I am Anand Sindhav from India. I am using coreldraw for billboard and hoarding design and it is very easy to create size like 40x20 Feet, 20x10 feet and 10x20 feet size in this software but I find trouble while using in Adobe Photoshop. I need your guidance to design billboard/hoarding design in Photoshop. How can I make small size in Photoshop and How can I enlarge it with original size of billboard like 40x20/20x20 size etc.
Lets take an example, I can create 40x20 (WxH) feet hoarding very easily in Coreldraw software but How can create such size in Photoshop as It becomes very bigger file while keeping this size. Now, In Photoshop, Creativity is endless so I like to create design in Photoshop but I find only one problem that is Size. Is there any method to create a smaller size of billboard design and we can create JPG output file with printing 72dpi/40dpi file format with exact size of 40x20 Feet. I need steps to solve this problem as I like to start work in Adobe Photoshop for Billboard design.
Question:
How can I create a smaller size/design of 40x20 Feet size hoarding in Photoshop? like can I reduce the proportion of feet into inch and divided proportionally and last proportion size can be created in Photoshop with maximum 300dpi resolution and at the time of making of output JPG file of 40x20 Feet, it can be created? Please provide your style of working to solve this problem.
Thanks a lot in advance for your guideline and steps.
Anand Sindhav
