Sliders will NOT Separate in "Blend If" when double clicked [2018]
  • April 23, 2018
  • 4 replies
  • 2940 views
Have used photoshop almost daily for around 20 years.
Double click works in all other software
Working on photo last night with no problems
12 working layers with blend if and separated sliders on 11.
I shut down computer in middle of the editing to get some sleep.
Windows 7 Updated when restarted today.
Opened same photo with 11 layers which use blend if with separated sliders which still work as normal
Added new layer
Blend if sliders will not separate on new layer.
Restarted computer
Opened new photo
Created a new layer from background
Blend if sliders do NOT separate.
Restarted computer and same problem
I work with wacom tablet
Disconnected tablet
Restarted computer
Installed mouse
Restarted computer
Same problem
Same problem on laptop touchpad
I can copy the layers which work correctly on the image to create new layers with working sliders.
I just cannot start any new layer and have blend if sliders which work
Problem probably with windows update but Adobe needs to get this working
Discussion  moved from Adobe Creative Cloud to Photoshop by moderator.
Correct answer jane-e
Did you try Option + Drag to separate the sliders? (Alt + Drag on Windows)
I just checked and it is working correctly for me.
Not working for me. Alt and double click do nothing to split the slider.
Stephen Marsh
quote
By @Gar
It always was and still is an ALT/OPT click and drag to split and separate the blend if slider.
Yes. First I've heard of double clicking it. You can type the whole sentence in caps if you like, it still doesn't work on my PC. Fine on the Mac.
D Fosse
Alt-drag is the way to do this. Double-click was new to me.
jane-e
Dag, double-click was new to me, too, and it did not work.
Only the way that we both know with Option or Alt works.
davescm
Jane
I just checked back as far as Photoshop 7.0 - always been Opt/Alt drag to separate sliders
I wonder if OP had something in his mouse/pen set up so that double click simulated Alt? It's all I can think of.
Dave
TensasAuthor
UPDATE
If I move the working sliders back together they will NOT separate again
jane-e
jane-eCommunity ExpertCorrect answer
TensasAuthor
UPDATE
jane-e
And you are using Option (or Alt), not double-clicking? Because I can't reproduce this, and I am trying.
When an Adobe program acts flaky for me, though, I quit and reset the preferences.
In Photoshop especially, it's important that you go into your panel menus first and save anything you have created, such as Action Sets, Brushes, Swatches, Gradients, Keyboard shortcuts, etc., so you can load them back in afterwards.
