[Strange problem] Change in brightness between two layers has same effects
I faced this Strange problem, I tried a lot to find out the reason behind the change in brightness and I couldn't.
this two shape draw with same color and some brush size,
The shape above, that I drew with a path and then a brush a week ago, was saved on a PSD file .
And now I try to apply the same thing to a new shape and put it to the same effect, but as you can see in the picture above, there is a difference in the effect and colors..
How can I find out what is the reason for this difference in colors?
