Have activation code for Premiere elements 2020, but need to use 2019 and code will not work [macOS]
  • January 22, 2020
  • 603 views
On MacOS (10.12.4) - I inadvertently got premiere elements 2020 and my system will only support 2019. 2019 will not accept my activation code and I am terrified to upgrade to high sierra in fear of having to upgrade a lot of other software. I cannot seem to find a location to ask for help with this and wondered if anyone could point me in the right direction.
Title edited by Mod
Correct answer Peru Bob
If you purchased it from Adobe, you may be able to get a refund:
https://helpx.adobe.com/in/x-productkb/policy-pricing/return-cancel-or-change-order.html
Adobe no longer sells PE 2019.
RosannacAuthor
Thank you.
Shivangi_Gupta
Hi Rosanna,
Thanks for writing in. As @Peru Bob mentioned, Adobe sells only the latest version i.e. Premiere Elements 2020. You may need to get in touch with the reseller for the Adobe Premiere Elements 2019.
Let us know if you have any other questions.
Shivangi
Peru Bob
