thevideomaker1234
Storage Help for my Two Hour Video!
  • August 14, 2018
  • 9 replies
  • 3026 views
You know how most of the things that are filling up my computer storage are the videos and photos of my Adobe Premiere Project right? And how if I delete it, Adobe Premiere Elements 9 will need to look for that specific video/photo? Well, I have copy/moved all the videos and photos that are related to my project from the original computer storage ( Local disk ), to the removable hard drive I have that can hold a LOT of storage. Now, my question is, if there is any way for Adobe Premiere Elements 9 to read, get, and use all the photo and video information from the hard drive instead of the Local Disk so it can be used in the project? If this happens, then I can delete the videos and photos that are from the local disk which can free up a lot of space while the  copied photos and videos that are in the hard drive are being used for Adobe Premiere Elements 9. Please reply and ask me questions if you are confused, I am trying to explain it the best that I can.
thevideomaker1234
What do you mean. Please go more into detail.
thevideomaker1234
How do I change it back if I wanted to?
Peru Bob
The same way you changed it before.
thevideomaker1234
I changed the drive letter to "B" instead of "K. I went back to Adobe Premiere Elements 9 and opened my project from my drive. I pressed my project name and it loaded, after a couple of seconds it STILL said "where is file _______.?" (This is talking about my photos and videos from my project). It is STILL not working. Whyyyyyyy?
P.S: I put all my photos and videos that were from my project inside a folder. I don't know if it makes a difference but I just wanted to tell you.
PLEASE help me in FULL DETAIL!
thevideomaker1234
Oh Okay. But what if I want to change it back?
You can change it back anytime you want to, but programs like Premiere Elements will get terribly confused.
thevideomaker1234
How do I change it back?
thevideomaker1234
Can you tell me how to do Disk Management? I am using Windows 7 by the way.
Try it and see. As I said above, external connections are not as fast as internal connections.
thevideomaker1234
It's funny how I have been waiting for a response yet no one has given me one yet. I thought you are supposed to help people? I have been stuck on this for over a month now!!!!!!!!
This is a user forum of volunteer users trying to help other users.  There is no paid, expert staff here.
That said, I've read, re-read and studied this series.  Short of moving in next to you and your computer, I'm at a total loss.   Bob's efforts have been clear and concise.
I think you may need to go to a computer repair service.  Your questions are operating system issues more than video editing issues.
Please have both good luck and success getting your computer fixed!
thevideomaker1234
Oh yeah. Okay I get it now. So, if I move my project from my computer hard drive to my external hard drive, then It will read the media from the external hard drive as well? And what do you mean that "it might not work as well"?
Peru Bob
If you are using Windows, make sure to use Disk Management to assign a permanent drive letter to the external drive so that Premiere Elements always knows where the files are.
thevideomaker1234
Is this the one??
SATA connections are the connections that connect your computer's internal drives to your motherboard.
As for your media's new location -- Didn't you say you moved all your media to an external drive? That's a new location, isn't it?
thevideomaker1234
Wait, what do you mean my "media's new location"? I am a little bit confused by that.
Also I don't know what SATA connections are
You can move your project file to your external drive and then re-connect it to your media's new location.
It just may not work as fast as it did when all of the media was on your hard drive. External USB connections aren't as fast as internal SATA connections.
