Adobe Premium Rush not Opening on PC - System Error
  • January 22, 2025
  • 489 views
Hi All
In our office we are having issue opening Adobe Premium Rush on one of our workstation PC's.
All other PC's can open Premium Rush.
Error message attached.
If anyone can assist I'd appreciate it.
We have tried reinstalling premium rush on the PC but hasn't resolved the problem.
Thanks
Correct answer Morriarchi
Cool. What was the source of the problem? Others may be able to help themselves in the future with such knowledge.
As you explained in your messages above.  Reinstalling / repairing the Visual Studio C++ runtime in add / remove programmes windows option.
It's a common problem apparently.
Thanks again.
Kevin-Monahan
Try reinstalling the Visual Studio C++ runtime: https://learn.microsoft.com/en-us/cpp/windows/latest-supported-vc-redist?view=msvc-170. I heard that can work, @Morriarchi. I hope it helps.
Hi Kevin
Thanks for the information. Unfortunately, it didn't fix the problem.
Are there other options you know of????
Kevin-Monahan
Thanks again.
Very cool. I really appreciate the response. Have a great weekend!!
Cheers,
