Problems with audio speed and pitch in Rush
I am working with a project where we are adding video clips to a presentation and adding separate audio clips over this. My group is having issues where every so often the pitch and speed of the audio changes without us changing it. Even after we fix it, it will still change later on. It has changed almost all of our audio and we are worried that once we finish the project it will randomly do it again, and we will have to fix the entirety of it.
caroline_edits
Hey there!
I'm thinking that maybe the bitrate or some piece of data within the audio file is different than the data within the video file, and Rush is getting a little confused. So sorry for the frustration! When you export the project, does the audio sound correct?
-Caroline
Kartika Rawat
Hi jdkoon!
Sorry to hear that the pitch and speed of the audio changes in Rush.
  • Which device are you using Rush on?
  • What kind of media files are you working with?
  • Do you get this issue with other audio files too?
Looking forward to your response.
Kartika
