Compatibility problem between Acrobat Pro and Indesign when using an interactive pdf create on In design.
  • March 31, 2017
  • 269 views
I have created buttons and checkbox on a document about indesign that I record in pdf interactive.  When I open it on acrobat, I click on the checkboxes, the button disappears well. However, when I uncheck the box this button does not reappear, while the parameters are entered in indesign (show / hide the buttons and forms).  I think this is a bug related to Acrobat Pro.
try67
You need to do that using a script, not using the built-in show/hide fields command.
