Edit Panel doesn't Display in Acrobat Pro - "repair" doesn't fix anything
- March 2, 2025
- 5 replies
- 1235 views
When I open a file in Adobe Acrobat - or even just the program and look at all tools - and select Edit PDF, I get an error message: Acrobat has encountered a problem. Some features may not work as expected. Try repair to fix the issue."
So I click repair. It does its thing. And nothing is repaired.
If I click cancel, the Edit Panel does not display, severely limiting any tools to actually edit. I'm at a loss how to fix this problem. Any suggestions? HELP?
