how to print specific parts of a page from a pdf in high quality
  • June 13, 2024
  • 1295 views
I want to extract a part of a page from my pdf in high quality. I searched online and found that I could do so by taking a snapshot . But after doing so, I found that when I zoomed in , the quality of the image was a lot worse from the original one. In the original on , even after I zoomed it to 1000%, I could clearly see the contents. Whereas, in the snapped one it was all blurry. Can anyone suggest a better method for doing this?
Correct answer JR Boulay
Yes, you can use the snapshot feature with Acrobat Reader.
However, you cannot use the page cropping tool, which is only available in Acrobat Pro and Acrobat Standard.
JR Boulay
JR BoulayCommunity ExpertCorrect answer
gary_sc
Just to verify, are you using Acrobat Pro or Acrobat Reader. The former can do this, the latter cannot.
A snapshot is a bitmapped image. By this I mean that it's an image of your screen. As you zoom in, you're seeing each pixel in your screen. The text in a PDF is usually (unless it's a scan that has not gone through OCR), a vector. That means that it's not composed of pixels, rather it's composed of points on the page with mathematical lines joining them. These are not composed of pixels, and look good at any zooming level.
I'm using acrobat reader, and I can still use the snapshot feature. Does that mean I have to purchase Acrobat Pro for the snapshot to be clear?
