How to split window vertically (side by side view)
  • April 13, 2022
  • 4 replies
  • 11719 views
The Acrobat Pro DC seems cannot split window vertically. In reading Journal Manuscript, we want to shift between pages of Figures and text. The 'split windows' is very efficient. However, the Acrobat Pro DC just split window horizontally. It is inefficient for reading. Is there some options to split window vertically?
Hi Dave
It loos like only pro has split ability, but the nomal version hasn't
this is a basic tool for PDF read, why it is not there for nomal version?
Meenakshi_Negi
Hi wonderful_Cosmos8984,
Thank you for reaching out.
Could you please tell us the Acrobat version number you are using? Also, what do you mean by "normal version" here?
Are you using Acrobat Reader? More information would be helpful.
Meenakshi
JR Boulay
"How to split one window into two (side by side)?"
OK, undestood.
Acrobat cannot split vertically.
Compared to BlueBeam Adobe is absolutelyh useless
Hi Boulay. Thank you for your reply! The tile is for two windows. What I want it to view one file with splitted view as follows.  How to split one window into two (side by side)?
Bernd Alheit
Use Window > Split
JR Boulay
A picture is worth 1000 words:
Dave__M
It may not meet your needs, but try Windows>Spreadsheet Split.  It will split your single doc into 4 smaller viewing panels, and you can adjust the divider by dragging it around.
Dave
