robertl87337782
If GTE is a total and CAE us a variable. What is the script for BDC if BDC = CAE-GTE if CAE>GTE or blank if CAE = 0 or is blank? A second script BDE where BDE=GTE-CAE if GTE>CAE or blank if CAE>GTE?
  • August 27, 2018
  • 827 views
Correct answer George_Johnson
They are names of fields (cash advanced to employee, grand total expenses - the other fields are BDC balance due company and BDE balance due employee).
OK, the custom calculation script of the BDC field could be something like:
(function () {
    // Get the input field values, as numbers
    var CAE = +getField("CAE").value;
    var GTE = +getField("GTE").value;
    // Set this field's value
    event.value = CAE > GTE ? CAE - GTE : "";
That final line of code is equivalent to the following if/else statement:
    if (CAE > GTE) {
        event.value = CAE - GTE;
    } else {
        event.value = "";
This should help you figure out the other calculation script, but if you get stuck, post again.
Have you looked a the JavaScript Reference Provided by MDN?
Look under Statements and Expressions and Operators.
robertl87337782
I have looked there, and some examples of scripts, but they all begin too far beyond where I am.  I have tried;
scripting  value to be entered in BDC:
if (CAE>GTE) = GTE - CAE;
else if (CAE=" ") = " ";
else if (GTE>CAE) = " "
Scripting value to be entered in BDE:
if (CAE>GTE) = " ";
else if (GTE>CAE) = GTE-CAE
When I enter these in the custom calculation script for a PDF form in Acrobat I get syntax errors.
This is just a simple PDF form and I have no experience with Javascript (the only experience I have in scripting was a required class 20-years ago using BASIC on a TRS 80.
Are CAE and GTE the names of fields, or something else?
