Aug 23, 2017 4:37 AM UTC
Is there a way to fix the static/noise problem in Record Audio comments in Acrobat?
  • Using the Record Audio comment feature creates a very poor quality sound file.
  • The issue relates to heavy static/background noise that overlays each audio file.
  • It is not related to the audio recording equipment & no other software is involved.
  • This problem appears to be at least 5 years old.
  • Add this to a development cycle and provide a timeline for this fix please.
Abambo
Jan 27, 2024 6:58 PM UTC
quote
By @Tony Els
You need to report that as a bug with https://acrobat.uservoice.com.
Jan 29, 2024 12:55 AM UTC
Thanks for this, I didn't know about it - couldn't find anything related so just reported it now.
https://acrobat.uservoice.com/forums/590923-acrobat-for-windows-and-mac/suggestions/47689505-bug-recording-audio-comments
JR Boulay
Jan 27, 2024 1:46 PM UTC
If you're using a Mac laptop you must unplug it.
Jan 27, 2024 6:06 PM UTC
Windows. Tried different laptops, differen audio sources (including an external mic) - no difference whatsoever.
Also noticed that if I forget to strain my voice to beat the background noise, it somehow records in this sort of "fade in" mode where the beginning of the comment is entirely inaudible.
Jan 27, 2024 1:24 PM UTC
I have driven myself insane trying to figure out why this happens... Literally shocked to find out the problem is over a decade old. Is there no intent by Adobe to fix this at all?
