Federico Cacciani
Feb 5, 2025 3:08 PM UTC
Problem filling modules fields using Pro while with Reader there is no problem. Javascript warning
I have a PDF file with pre-stated modules to fill and return to the company who made it.
If I fill it using Acrobat Reader there is no problem but if I fill it using Acrobat Pro when I save it appears a javascript warning and then the filled file is rejected from the main system where I'm uploading (there is no problem if I use the Reader).
As it's not possible to have both Pro and Reader in the same PC, I find this obviously very nervy.
Any solutions?
Is it possible to make Pro "downgrade" and work as a Reader? Or saving the faile as if made by a Reader?
Using:
Win 11 Pro
Updated Acrobat Pro
Warning popup:
Attached one copy of the file:
try67
Feb 5, 2025 4:08 PM UTC
You did not attach a copy of the file.
This message is generated by a script, so it should be possible to remove or modify it, if the file is not secured.
