Standortmarker - Verschiebbarkeit eines Bildfeldes per Drag and Drop durch den Nutzer ermöglichen
  • October 9, 2024
  • 5 replies
  • 1327 views
Hat jemand schonmal Nutzerverschiebbare Felder in ein Formular eingefügt und kann mir genau beschreiben wie das geht?
    Ich möchte das Nutzer im Formular das in Größe und Inhalt fest vordefinierte Bild eines Standortmarkers welches vor dem  dem Bild einer Landkarte liegt, an den von Ihnen gewünschten Standort verschieben können.
    Yes, I'm trying to do it with acrobat but I can not make it work. i want the users to be able to drag and drop a per-defined lokation-marker so that this marker can be saved exactly at this position.
    kglad
    eg, acrobat?
    jane-e
    @daniela_plessa
    Can you tell us which Adobe application you are using?
    Jane
    Adobe Acrobat 2024
    jane-e
    @daniela_plessa
    Hi Daniela, I've moved your post from Using the Community to the Acrobat forum for you.
    Jane
     Hello, I want to set the image field ‘Location’ which represents a location marker so that the user of a fillable acrobat form can move it on this by drag and drop, so that this image is then saved in the form in the appropriate place. Has anyone ever done something like this successfully? - Answers from the AI have failed so far.
    Big thanks for your help
    and greeting Daniela
    try67
    A user can't drag and drop a field. However, a script can be used to indicate the location of the field on the page, but only if the full page is a button. This is quite tricky to implement, but I've done similar things in the past, and would be happy to work on it for you.
    If you're interested in hiring a professional to create it for you, feel free to contact me privately by clicking my user-name and then on the blue "Message" button.
