Need help with Executor Delta
  • November 4, 2025
  • 186 views
Hello everyone, I'm having trouble with Executor Delta for Roblox.
Problem: When I try to open or attach it to Roblox, it crashes, shows a fatal error, or doesn't inject.
What I've tried:
  • Reinstalled Executor Delta.
  • Disabled Windows Defender
My system:
  • Windows 10 (64-bit)
  • Latest version of Roblox
  • Stable internet
Questions:
  • Is there a new update or patch that I missed?
  • Does it require a specific .NET framework or runtime?
  • I'm looking forward to your response. Thanks!
    John T Smith
    mandelta
    1. Is there a new update or patch that I missed?
    Yes. Since Roblox updates every Wednesday, Delta usually releases a new patch within 24–48 hours to maintain compatibility.
    • PC/Windows: A new update was pushed around March 16, 2026, to address injection issues with the latest Roblox client.
    • Mobile (Android/iOS): Ensure you are using the latest version (likely v2.x) released earlier this month. If your current version is crashing upon "Attach," you definitely need to download the latest APK/IPA from the official source.
    2. Does it require a specific .NET framework or runtime?
    Yes, for the Windows version to function correctly and avoid "DLL missing" or "Initialization" errors, you typically need:
    • .NET Framework 4.8 or 4.8.1: Most launchers are built on this.
    • Microsoft Visual C++ Redistributable (2015–2022): You need both the x64 and x86 versions. This is the most common reason for "Incomplete Injection" errors.
    • DirectX End-User Runtimes: Occasionally required for the overlay/GUI to render properly.
    Quick Tip: If you are using an emulator (like MuMu or BlueStacks), you don't need these runtimes inside the emulator, but you should ensure your Windows host has them installed to keep the emulator stable.
    For Delta Scripts you may follow this Official website hscriptdelta.com
