Please Help Me Fix Executor Delta?
  • November 2, 2025
  • 5 replies
  • 2752 views
Hi everyone,
I’m having an issue with Executor Delta and I’m hoping someone can help me figure it out.
Here’s what’s going on:
  • I recently downloaded Executor Delta for Roblox scripting.
  • When I try to open or attach it to Roblox, it either crashes, shows a key error, or doesn’t inject properly.
  • I’ve tried reinstalling it, disabling antivirus, and downloading from the official site still no luck.
My system details:
  • Windows 10 (64-bit)
  • Antivirus: Windows Defender (temporarily disabled)
  • Roblox version: Latest
  • Internet connection: Stable (fiber)
What I’ve tried so far:
  • Restarted PC and reinstalled Delta.
  • Cleared temporary and Roblox cache files.
  • Ran it as Administrator.
  • Checked for missing DLLs.
My questions:
Is there a new update or patch for Executor Delta that I might have missed?Does it require a specific .NET Framework or runtime version?Is there any known compatibility issue with the latest Roblox update?
If anyone has a working setup or fix, please Share Here  I’d really appreciate the help.
    kglad
    post in the after effects beta forum if you have questions related to after effects beta.
    It sometimes takes 15+ seconds to render solids in After Effects Beta, even when using Delta Executor. Anyone else seeing this delay?
    lucilamorgan
    I squandered forty minutes attempting to change the URL of my PDF online. I only required Google Drive. I appreciate your assistance with the sportzfy. The answer was simple and rapid.
    kglad
    how is your post related to adobe?
    daniellei4510
    Um. I think you might be asking the wrong forum.
    Adobe Community Expert | If you can't fix it, hide it; if you can't hide it, delete it.
    kglad
    is this a substance 3d question?
