UI style guide example for Angular Material Design
  • May 3, 2018
  • 4947 views
I am looking for UI style guides based on Angular Material Design for some inspiration. Please share links if you have any.
Thanks!
    magical_Skyline0D4A
    Hello, this is not exactly a question about Adobe products, but the answer to your question is in Angular Material https://material.angular.io/guides
    John T Smith
    Which Adobe program are you using?
    I am using Adobe XD.
    Trevor.Dennis
    Are you OK with this thread being moved to the XD forum?
