Specific Issue (Problem) with Audition 3.0
Jun 27, 2017 Jun 27, 2017
using Audition 3.0 in Windows 10......
when opening Audition, getting "record not possible, sound card not compatible with DirectSound input".....
using Yamaha AG06 USB interface .....
have installed the drivers for both the AG06...AND....an ASIO4all (told that is a comprehensive driver) and already have Windows 3.0 Sound driver as a generic
when using AG06 driver, Audition 3.0 WILL, in fact, record, but I cannot get play back........
when using Windows 3.0 Sound driver, I GET playback from Audition (and other media on the PC), but CANNOT record in Audition.....
when attempting use of the ASIO4all, I cannot get a "consensus" that allows me to record and playback on Audition while being able to continue hearing playback on other media......
what should be a simple process has turned into a "who's on first?" I have not had to deal with in past installs, versions, etc......
any clarity would be much appreciated.....thanx
TOPICS
Version 3 and earlier
746
Oct 11, 2017 Oct 11, 2017
[Moved from the defunct Getting Started forum into a product-specific support forum - moderator]
LEGEND ,
Oct 12, 2017 Oct 12, 2017
Do you have the latest Yamaha USB drivers 1.9.10-2 installed? In the Audio Driver drop down box for either Edit or Multitrack view can you see Yamaha ASIO (or something similar)? And can you select it for use? To work properly Audition 3 requires an ASIO driver from the audio interface's manufacturer.
