P: Problems with "Copy settings" when i clicking in develop mode
Sep 11, 2025 Sep 11, 2025
Hello!
Today i have a problem. When i try edit photos on lightroom classic develop mode, everywhere when i clicking apper window with "Copy settings"
I tried to resolve this problem with all ideas from internet, i tried old version of lightroom, new catalog, hotkeys, i disconect keyboard, mouse etc etc and nothing work!
I tried even if shortcut (CTRL+SHIFT+C) work but this shortcut DONT work ... What can be? Window from this shortcut apear only when i click anywhere on develop mode (1-2-3 clicks, depend)
Please, i need help fast!
Thanks a lot!
TOPICS
Windows
1.6K
New Here , Sep 12, 2025 Sep 12, 2025
Guys! I think (atleast for me) i found the problem!
I started the computer in safe mode + network.
I launch the lc and i try to find if the problem persist... but NO, problem dont apper on safe mode.
I turned computer out from safe mode, i launch lc and problem was there. So, some aplication send me thet error in lc...
After a lot of search, i found the aplication wich create problems in lc. Aplication was TRIO OFFICE (is for xls/world reader/edit etc). If i turn off this aplication, lc work correc
Sep 14, 2025 Sep 14, 2025
@TewRogers
Check the answer maked as 'Correct Answer' at top of thread as it may be the solution to your issue.
Community Beginner ,
The issue is not resolved.
I found the issue to be with windows having trio offfice open in the background. Once i closed that trio office the issue completely stopped.
6 hours ago 6 hours ago
This was the fix, thanks Darius.
I have found another work around...... opening Lightroom classic as an administrator will stop it from popping up, only thing is that you  have to launch it as administrator everytime.
Disabling Trio Office through task manager worked.
LRC ogni volta che muovo un cursore di modifica di qualsiasi genere o ritaglio foto mi si apre copia impostazioni e devo chiuderlo sempre... aiuto
11 hours ago 11 hours ago
@Francesco Minolfo Fontana
Hola que tal. Estoy teniendo un problema con lightroom classic. El problema es que me sale a cada rato la pestaña de "copiar ajustes" da igual lo que esté haciendo, no me deja editar fotos de lo regular que sale. Necesito buscar la forma de hacer que deje de salirme
Try resetting the preferences of Lightroom Classic:  How to reset Lightroom Classic preferences (adobe.com)
It's recommended to backup your preferences before you reset the preferences to the default settings:
https://helpx.adobe.com/lightroom-classic/kb/preference-file-and-other-file-locations.html
My System: Intel i7-8700K - 64GB RAM - NVidia Geforce RTX 3060 - Windows 11 Pro 24H2 -- LR-Classic 14 - Photoshop 26 - Nik Collection 8 - PureRAW 5 - Topaz PhotoAI 4
@mauro_4930
3 hours ago 3 hours ago
I've noticed that lately when I use the crop tool, the "Copy Settings" dialog pops up too. I've un-installed and re-installed LR. I've rest the Preferences. I've disconnected all my external editing keyboards. I've swapped around different standard keyboards. All without any change to this strange behaviour. I'm out of ideas. Anyone else experience this behaviour/bug and /or can help?
I've attached my System Info details, in case it helps.
TIA
2 hours ago 2 hours ago
Hello Clive,
You probabely have a conflict with another software. A friend of mine had troubles with a software named TRIO OFFICE.
It start when you boot your computer and make such kind of troubles.
If it isn't this one , try the method i wrote in my answer to @ Alain 7744
You should find the wrong software for Lightroom
That was it!! You're a life saver. I didn't even realise TRIO OFFICE was running in the background.
Thank you so much!!
Hi guys, today Lightroom gave me an annoying problem: Copy Settings opens by itself. What should I do?
Thanks for the replies, I hope to fix it because it's become unusable.
@Michele Ducato
