Tethering not recognizing Nikon D850 under Rosetta (M1 Max Studio - current LRC)
May 04, 2022 May 04, 2022
OS: OSX Monterey 12.3.1
H/W: Mac Studio - M1 Max 32GB
Software: LRC 11.3.1
Camera: Nikon D850
Issue
Start Teathered Capture, which creates a popup to relaunch LRC under Rosetta.
When LRC is running under Rosetta and you select start tether,
On the first attempt LRC crashes.
LRC needs to be restarted and the launched under Rosetta again.
On the second and subsequent "Start tethered capture", LRC fails to detect the attached Nikon D850 camera.
The camera is connected by a known working usb-C port via known working PRPteather usb cable, This same camera, cable setup works when conected to a windows 11 laptop running LRC 11.3.1
TOPICS
macOS
3.0K
Feb 06, 2023 Feb 06, 2023
Nikon has a professional Tether application which they provide at a cost to users who purchase their Professional camera models, is the Nikon Software inferior to Tether capture in LrC?
Why buy a Nikon Camera if you don't get the Software to utilize the Camera's features?
Regards, Denis: iMac 27” mid-2015, macOS 11.7.10 Big Sur; ( also laptop Win 11, ver 23H2; LrC 13.4,;) 2TB SSD, 24 GB Ram, GPU 2 GB; LrC 12.5,; Lr 6.5, PS 24.7,; ACR 15.5,; Camera OM-D E-M1
Votes
I confirm that after upgrading to Ventura 13.2, Macbook M2, 16GB RAM, HDD 256 GB, LRC 12.1, Nikon D850 firmware 1.30 it still works (worked with 13.1 too). Didn't work with previous firmware for the camera.
Votes
Explorer ,
Feb 07, 2023 Feb 07, 2023
For an M1 Macbook Air (Ventura 13.2) with Nikon 1.30 firmware, it does not work.  Does not work with 13.1 either.  Also tested on my M1 MacMini (13.1 then 13.2) with no success.
So, I'll patiently wait for the fix.  In the meantime, I'm very happy with Capture One and will probably switch permanently after my Adobe subsrciption expires.
Votes
Explorer ,
NX Tether does not work with the D850.  Only the Z line and the D780.
Votes
Really? That is crazy. Didn't even realize it as I only use my z-series cameras anymore nowadays but you are right that is what it says on the support pages.
Votes
Explorer ,
Sorry for the duplicate post below.
So yes, I tested it and it doesn't work.  I saw the supported cameras, but was hoping the D850 would work anyway.  No such luck.
Votes
Explorer ,
Votes
Explorer ,
Feb 16, 2023 Feb 16, 2023
The latest LRC update (12.2) has fixed the D850 tether problem.  Thanks Adobe!!!
Votes
LEGEND ,
@defaultdtc1l55c74l5wrote, "The latest LRC update (12.2) has fixed the D850 tether problem. "
 Are you running LR under Rosetta or native Apple Silicon?
Votes
Explorer ,
Feb 17, 2023 Feb 17, 2023
It's running under Rosetta.  Same as before it stopped working.
Votes
