Techies! I am stumped on something that probably has an easy fix. I have 2 images shot at the same aspect ratio, but they look like different aspect rations. They're both 4x6 and the same dimensions, but visually, one is smaller than the other. Has anyone had this happen? I've looked at the file information, compared RAW files, and viewed in LR and PS and can't figure out what is happening.
A screenshot says more than a thousand words. Photoshop can work with non-square pixels, but without a screenshot and exact details (like how many pixels each image has on each side) my guess is as good as yours.
Hi Elisaf,
Could you please explain the issue you're facing in more detail with the help of a few screenshots? Which version of Lightroom and Photoshop are you using? Where(which application) are you viewing these images in?
Akash
