print module problems with print module paper size
Oct 28, 2020 Oct 28, 2020
I don't have a printer I send it out to be printed. When I try to set up the page the only options I have are fax, microsoft reader and something else because of this my paper size options are worthless. I have noticed on videos they pick all printers then custom sizes, I don't have either, Why? Lightroom CC latest version.
TOPICS
Windows
151
Oct 29, 2020 Oct 29, 2020
So your "Lightroom CC latest version" is- Lightroom 4.0 or Lightroom-Classic v10.0
In Lightroom you would Export a JPG to send out.
In Lightroom-Classic you can also Export a JPG in the Export module.
Or, if you want the Watermark and Identity Plate features of the Print Module you would set the Print Job to 'Print to:" a JPG file and enter the required particulars-
Regards. My System: Lightroom-Classic 13.2 Photoshop 25.5, ACR 16.2, Lightroom 7.2, Lr-iOS 9.0.1, Bridge 14.0.2, Windows-11.
Votes
