Need help with with auto color correction options/curves layer
May 08, 2021 May 08, 2021
So with the curves layer, I use the auto color correction options to help make two or more different images colors to match, specifically the find dark and light colors options. Now I'm having issues when I try to choose the highlight and shadow options, I'll try my best to explain. When I try and choose one either shadow or highlight, choosing the second comes with complications. Before when I would choose the colors from images, it would be seamless. Now choosing the second one, the color is a bit too much or sometimes it will turn into solid white or black. Also, when I would click on the screen and wasn't satisfied with the color, then click another area of the image, the color would change accordingly. Now when I do that it, like it adds both colors. Hopefully that makes sense. I've reset photoshop to factory settings, I've tried clicking d, I don't know what else to do. Any help would be appreciated. Thanks in advanced!
TOPICS
Actions and scripting
1.0K
Adobe
LEGEND ,
Votes
People's Champ ,
Can not understand anything. Could you please record a video showing your problem?
Votes
