Technical issues, Rejected due to technical issues, technical issues rejections
Nov 01, 2021 Nov 01, 2021
What do you think ? why all my photos are rejected ? For example this one ?
TOPICS
Contributor critique , Contributors , Fotolia , Troubleshooting
319
Check the focus, your pictures are out of focus. It is important that your subjects are in-focus. With the first picture for example, a little part of the stem of the right flower with the fly is in-focus, instead the fly and the blossom.
If you are new to stock, you should consider these resources: https://helpx.adobe.com/stock/contributor/tutorials.html
Please read the contributor user manual for more information on Adobe stock contributions: https://helpx.adobe.com/stock/contributor/user-guide.html
See here for rejection reasons: https://helpx.adobe.com/stock/contributor/help/reasons-for-content-rejection.html
and especially quality and technical issues: https://helpx.adobe.com/stock/contributor/help/quality-and-technical-issues.html
Votes
Hi @Bahadır5EEA ,
None of your photos' subjects are completely focused. It appears you did not have correct settings for f-stop. The fourth one is also noisy and underexpose.
Best wishes
JG
Photographer and Nutrition Author
Votes
Nov 02, 2021 Nov 02, 2021
Everything in the food tray is unfocussed.  This is not acceptable for commercial use.  Sorry.
Adobe Stock customers expect the highest visual and technical quality for use in their own projects.  See links below.
Alt-Web Design & Publishing ~ Web : Print : Graphics : Media
Votes
