Jun 12, 2023 8:24 PM UTC
Open for Voting
couldn't find required item at project path "/ProjectItems/Parts/Scene Puppet 7"
I can't access to my Ch project no more... When I try to open my file, this error message appears, I cant work on it no more. This is a three month work I was about to finish.
Can someone helps me please ?
Is there a way to use a previous save of my work ?
Jun 12, 2023 11:30 PM UTC
If you can zip up your project and send me a private message with a download link, I may be able to figure out what went wrong and roll it back or fix it.
When you dismiss the error, does it just pop up again? If not and you can get to the History panel (in the Window -- probably "Fenétre"), you may be able to go back to an earlier state before the error happened. Also, if you start the app with the Shift key down, it clears UI data which might avoid this error. (basically it clears selection, closes all the puppets and scenes, etc, the main project data is left intact)
If any of those options work, I would still like to inspect at least the Ch Data/repo.noindex folder and errors-by-oid.log file since it is possible I'll be able to figure out the underlying issue that got the project into this state so it can be fixed in a future version to prevent the same error from happening again.
Dan Tull
Adobe Character Animator Team
Jun 12, 2023 8:32 PM UTC
Here is the message error
