idahochukar
Oct 24, 2020 4:36 PM UTC
Released
P: Problem when using copy and paste or sync in develop module with WB changed
My operating system is MacOS Catalina 10.15.7. With the new LRClassic update 10.0. When I change the WB from As Shot to Daylight in the Develop module with the Profile at Camera Standard (Nikon D500 and D850 user) whether I have made other changes to other sections of the basic panel or not and then copy and past to another photo or sync to other photos (same sequence and same camera WB settings) the WB label changes to Daylight in the photos copied to or synched but the sliders (and the setting) do not change. I then have to go to each individual photo copied to or synched to and change wb back to as shot and then to Daylight and then it works although then the preveviews in the thumbnails in the film strip below are erractically slow to resolve. This does not happen if I have just changed the Temp or Tint slider or both but only if I have clicked on the Daylight option. I have tried disabling all plug ins and no change, I have turned of the computer completely and turned it back on etc.. .
adriandavidpayne
Nov 8, 2020 8:13 PM UTC
Arjun_Haarith, are you aware the Presets BUG from version 11 is BACK?  This is beyond frustrating!
I made this video several versions ago, and it was fixed and now it is BACK!
https://www.youtube.com/watch?v=-gOiOzjgr6s
Nov 7, 2020 8:55 AM UTC
I can confirm the same behavior with LrC V10 on an iMac running on MacOS Catalina 10.5.7. Copy and paste / sync of white balance doesn't work properly. Seems to be that white balance can' be synced.
TheDigitalDog
Nov 6, 2020 1:52 PM UTC
It's a known and reported bug Adobe is aware of and will fix.
Author “Color Management for Photographers" & "Photoshop CC Color Management/pluralsight"
ouiouiphoto
Nov 6, 2020 12:50 PM UTC
I confirm this behaviour. If you chose any of the WB preset and copy paste the white balance you will paste the preset name but not the value. Except for personal values
.Sheepdog trying to help Lightroom and Photoshop beginners
Nov 6, 2020 11:56 AM UTC
When copying the White Balance 'Flash' and pasting it on another photo in the Develop module the label 'Flash' is pasted, but the values are not pasted.
Pasting custom White Balance values does work.
Nov 3, 2020 9:24 PM UTC
Thank you John. I'll do that.
johnrellis
Nov 3, 2020 8:12 PM UTC
Khphotog,
I observe the same behavior. Please post this to a new thread, since it's a different set of symptoms and the developer most likely see your post buried here.
Nov 3, 2020 7:24 PM UTC
@Rick
I am experiencing a similar problem with Copy and Paste. When I Check All in the copy function and then uncheck Color Grading, Color Grading is always copied anyway.  If I uncheck everything and then individually check each box except for Color Grading it works as it should.
arjunhaarith
Adobe Employee
Adobe Employee
Nov 3, 2020 4:21 AM UTC
Hi Jason,
Yes, we are aware of that.
As a workaround you can use 'Auto Sync'
Arjun
