idahochukar
Oct 24, 2020 4:36 PM UTC
Released
P: Problem when using copy and paste or sync in develop module with WB changed
My operating system is MacOS Catalina 10.15.7. With the new LRClassic update 10.0. When I change the WB from As Shot to Daylight in the Develop module with the Profile at Camera Standard (Nikon D500 and D850 user) whether I have made other changes to other sections of the basic panel or not and then copy and past to another photo or sync to other photos (same sequence and same camera WB settings) the WB label changes to Daylight in the photos copied to or synched but the sliders (and the setting) do not change. I then have to go to each individual photo copied to or synched to and change wb back to as shot and then to Daylight and then it works although then the preveviews in the thumbnails in the film strip below are erractically slow to resolve. This does not happen if I have just changed the Temp or Tint slider or both but only if I have clicked on the Daylight option. I have tried disabling all plug ins and no change, I have turned of the computer completely and turned it back on etc.. .
Nov 3, 2020 2:02 AM UTC
Hey there, just letting you know this isn't limited to the Mac version, getting the same thing here on Windows, just updated last night, regretting it right now...
It updates the WB name to whatever you copied, Daylight, Custom etc but doesn't change the values Temp and Tint thus no change to the image itself.
arjunhaarith
Adobe Employee
Adobe Employee
Nov 2, 2020 9:53 AM UTC
Hi Kenn,
We are aware of this and are working on fixing it.
It'll be addressed in the future release.
Arjun
Nov 2, 2020 7:14 AM UTC
The new Lightroom Classic 10.0 Mac wont sync the whitebalance settings in the develope module. The checkbox is on for syncing whitebalance, but nothing happens with the rest of the selected images when applying the settings. This is quite annoying …
arjunhaarith
Adobe Employee
Adobe Employee
Nov 2, 2020 4:24 AM UTC
Hi Michael,
Yes, we are aware of this issue, and it will be addressed in the future release.
As a workaround you can use 'Auto Sync'
Thanks a lot.
Arjun
TheDigitalDog
Nov 1, 2020 11:48 PM UTC
What's happening with a paste is the actual WB menu gets updated but not the image. If you actually select the WB from said menu, it works. So yes, it's a bug and Adobe is now aware of it. Good catch!
Author “Color Management for Photographers" & "Photoshop CC Color Management/pluralsight"
TheDigitalDog
Nov 1, 2020 11:36 PM UTC
Yeah, something isn't right on this end either (Mac OS).
I DO see the WB label change from say As Shot to Fluorescent but I don't see the color appearance update. I'll file a bug report.
Nov 1, 2020 10:59 PM UTC
If you select one of the standard present white balance settings (example: Daylight) and copy settings, when pasting to another photo the white balance is not applied.  If you copy a custom white balance then this is applied.
In previous versions this worked as expected
idahochukar
Oct 26, 2020 1:44 PM UTC
@arjun_haarith You'r welcome and thank you
arjunhaarith
Adobe Employee
Adobe Employee
Oct 26, 2020 6:24 AM UTC
Thanks a lot Ken, for reporting this, and others for confirming.
We are able to reproduce and are investigating the issue.
Arjun
KR Seals
Oct 26, 2020 12:22 AM UTC
Win 10 Pro - LrC V10
I see the same behavior. In develop, changing the white balance on the main image, then selecting another image or images the Sync function does not work on the adjacent image or non-contiguous ones.  If I adjust esposure and WB, then sync, both values get synched.
In the Library module, Grid view, change the white balance in quick develop and use the Sync Settings button results in no sync of the WB. But, the WB field in quick develop does show that the value "tungsten" in this case has changed. When I try to sync the change in two values, WB and exposure, the exposure syncs, but the WB does not.
I tried just changing the WB in Grid View on an image and nothing else. Then the sync with the adjacent image worked ok if I also had Basic Tone checked, even though I had not made any changes to those items.
Ken Seals - Nikon Z 9, Z 8, 14mm-800mm. Computer Win 11 Pro, I7-14700K, 64GB, RTX3070TI. Travel machine: 2021 MacBook Pro M1 MAX 64GB. All Adobe apps.
