idahochukar
Oct 24, 2020 4:36 PM UTC
Released
P: Problem when using copy and paste or sync in develop module with WB changed
My operating system is MacOS Catalina 10.15.7. With the new LRClassic update 10.0. When I change the WB from As Shot to Daylight in the Develop module with the Profile at Camera Standard (Nikon D500 and D850 user) whether I have made other changes to other sections of the basic panel or not and then copy and past to another photo or sync to other photos (same sequence and same camera WB settings) the WB label changes to Daylight in the photos copied to or synched but the sliders (and the setting) do not change. I then have to go to each individual photo copied to or synched to and change wb back to as shot and then to Daylight and then it works although then the preveviews in the thumbnails in the film strip below are erractically slow to resolve. This does not happen if I have just changed the Temp or Tint slider or both but only if I have clicked on the Daylight option. I have tried disabling all plug ins and no change, I have turned of the computer completely and turned it back on etc.. .
Todd Shaner
Oct 25, 2020 10:59 PM UTC
I knew that! Thanks Rick........just a senior moment!
Rikk Flohr-Retired
Adobe Employee
Oct 25, 2020 9:18 PM UTC
Other Rick....
johnrellis
Oct 25, 2020 4:27 PM UTC
"[It] only works in the Library Grid view"
Right. 10 years on and I stil get confused about selections and Loupe.
Todd Shaner
Oct 25, 2020 4:15 PM UTC
Thanks Rikk. I also tested ACR 13.0 and it does not exhibit the issue.
idahochukar
Oct 25, 2020 2:30 PM UTC
Thank you ... I find that most of the time my D850 does great with auto wb but my D500 frequently is a bit off from where it should be in full daylight using auto wb so that is the most frequent drop down menu I use so had not noticed the others yet.
Rick Spaulding -
Oct 25, 2020 2:27 PM UTC
Another work around is to turn on Auto Sync in the Develop module. Good catch on this by the way. I normally work in Auto Sync mode and would never have noticed this.
Rick Spaulding -
Oct 25, 2020 2:23 PM UTC
I see this behavior as well and will write a bug for it. It seems to happen whenever a WB setting is changed from the drop down menu in the white balance edit panel. It behaves this way for all drop downs except Custom. Perhaps because you have to actually move a slider to make a custom setting.
Todd Shaner
Oct 25, 2020 2:10 PM UTC
John, on my Windows 10 system that only works in the Library Grid view, which I believe is normal behavior.
johnrellis
Oct 25, 2020 12:31 AM UTC
A workaround: In Library loupe or grid view, select the photos, and in the Quick Develop panel, change White Balance to Daylight.
I haven't extensively tested it, but it worked on the few test cases I tried.
Conrad_C
Oct 24, 2020 7:30 PM UTC
Observed this yesterday. Good to see it already reported.
