idahochukar
Oct 24, 2020 4:36 PM UTC
Released
P: Problem when using copy and paste or sync in develop module with WB changed
My operating system is MacOS Catalina 10.15.7. With the new LRClassic update 10.0. When I change the WB from As Shot to Daylight in the Develop module with the Profile at Camera Standard (Nikon D500 and D850 user) whether I have made other changes to other sections of the basic panel or not and then copy and past to another photo or sync to other photos (same sequence and same camera WB settings) the WB label changes to Daylight in the photos copied to or synched but the sliders (and the setting) do not change. I then have to go to each individual photo copied to or synched to and change wb back to as shot and then to Daylight and then it works although then the preveviews in the thumbnails in the film strip below are erractically slow to resolve. This does not happen if I have just changed the Temp or Tint slider or both but only if I have clicked on the Daylight option. I have tried disabling all plug ins and no change, I have turned of the computer completely and turned it back on etc.. .
Oct 24, 2020 7:12 PM UTC
I can confirm that this is happening on Catalina 10.15.7 on a MacBook Pro and Lightroom Classic 10.0 using Sony .awr files that have been converted to .dng files upon import.
Todd Shaner
Oct 24, 2020 6:02 PM UTC
I tested LrC 9.4 (previous version) and it does NOT exhibit this issue so the bug was introduced in LrC 10.0. Just a confirmation for Adobe Engineering.
Todd Shaner
Oct 24, 2020 4:58 PM UTC
I can confirm the same behavior on my Windows 10 system using LrC 10.0.
