Nov 13, 2023 8:31 PM UTC
Released
P: Shutter Sync issue for iphone 15 pro max on 5x telephoto lens Raw
Hi all,
 I was hoping the most recent update (9.0.1) would fix, but it appears the bug still persists. If you take a raw photo in the lightroom app using the iphone pro max telephoto (5x) you can see issues with what appears to be shutter sync. It is especially apparent if you take a flash photo, as you often get a black bar or no readout all together.
jkz-Author
Jan 18, 2024 1:55 PM UTC
I still see the issue as well. I am starting to worry it's a hardware issue.
Gleeful_mind5C4F
Jan 10, 2024 6:23 PM UTC
I still see the issue on 17.2.1
DonG46
Jan 10, 2024 3:46 PM UTC
It appears that the latest version of IOS 17.2.1 fixes the problem.
Gleeful_mind5C4F
Dec 2, 2023 3:50 PM UTC
Just noticed this today as well, glad to know it's a software issue and not a hardware issue and that I'm not the only having this problem.  That said, I don't have anything to add except that my experience is another data point.
hellsdays
Dec 2, 2023 12:25 AM UTC
Hey @Charlie.D It seems that this topic is more relevant, check it out. A few users have the same issue.
iPhone 15 Vignetting issue
Adobe Employee
Nov 30, 2023 6:36 PM UTC
Hello @hellsdays
Thanks for taking the time to post about this, and providing details you like did.  We will try to validate this issue in-house for a bug report.
Question: does this happen with all lenses?  Or perhaps just the 5X lens?
hellsdays
Dec 1, 2023 10:19 AM UTC
Hey @Charlie.D thank you for the quick response. As far as I can tell, this happens only with 5X lens.
Adobe Employee
Dec 1, 2023 6:17 PM UTC
To help us track this on our side, I'm going to merge your post with an existing thread going that relates to the iPhone 15 5X lens.  We've reported a bug to Apple and are awaiting a fix in iOS for this issue.  We currently no ETA for the fix, but will follow up in the thread when we know more.
Rikk Flohr-Retired
Adobe Employee
Nov 13, 2023 8:59 PM UTC
Thanks for the report. We have a bug logged in our system.
