Team project is stuck in a loop for unpublished, unmerged changes just after project load
- June 21, 2025
- 2 replies
- 291 views
For one of the sequences in our team project, I'm getting a message that another person is editing the sequence and that I have unpublished changes that will be copied to a new sequence. When I click "OK", the dialog disappears and an "Update Project Items" dialog comes up shortly after. After a few moments, the dialogs reappear and repeat, even without intervention. In this particular case, I haven't even personally opened the sequence being called out as conflicting since I first published the team project.
I'm attaching a screen recording that starts with a fresh state after deleting the local project cache. There is a black box obscuring a name that exists throughout the recording. I scroll the project files with the mouse wheel once, I move the mouse around, and I click the "OK" button on the dialog for all the actions I'm doing in the recording.
Repro steps
1. Publish a large, existing project with many sequences as a team project. This project started as a CS 5.5 project and has been upgraded through multiple releases to an Adobe Premiere 2025 project before publishing as a team project.
2. Share the project with a partner.
3. Publish the first round of updates due to Premiere processing metadata in the background.
4. Close your local instance.
5. Have the partner open the project and publish the second round of updates due to Premiere processing metadata in the background on their computer.
6. Reopen the project locally and wait for the the "Save A Copy" dialog for the conflicting sequence.
Expected: Clicking "OK" will save a copy and be done with it until the next manually initiated update using the "Update" button.
Actual: Clicking "OK" saves a copy, but the modal dialog automatically reappears after a few moments, causing an infinite number of duplicate sequences to be created and blocking any meaningful work due to the two dialogs being modal.
Adobe Premiere Pro 2025 (25.3.0 - build 84)
Plugins installed:
- Frame.io V4 Comments
- Freesound Audio Search
- Vimeo Panel
Windows 11 Pro, 24H2, 26100.4349
Windows full build version: 26100.1.amd64fre.ge_release.240331-1435
AMD Ryzen 9 5950X
NVIDIA RTX 4070 Super with NVIDIA Studio Driver installed
GoPro Quik 2.3.0.5383 with the Cineform HD VFW Codec 9.2.1.690 installed (used by most video media in the project)
