Feb 7, 2023 9:02 AM UTC
Open for Voting
Smooth over parts of a body recording
You know what would be cool? I'm using the body recorder for full body recordings, and it works pretty well. Well, aside from the glitches where the body decides to become a foot taller for a second or two or the head decides to stick to one spot while the rest of the body moves as expected. Well, it'd be cool to maybe have an option to smooth over parts of a body recording between a couple frames, or have it be like another recording where you could use the blend-in and blend-out sides. It would basically take the body data from the beginning of the range and the body data from the end and just blend those two, ignoring the spots in between. Then you could use it to patch the glitches to make the performance much smoother. I'm using draggable handles right now to fix a frame or two here and there, but it can only do so much. Without the ability to record a frame for one body pose or edit the body poses manually, this could be the next best thing.
