Open for Voting
Remember Render and Replace Location per Project
  • June 16, 2026
  • 15 views
Currently when using “Render and Replace” you pick a location to render to, but no matter what project you open, that location is set to the last location you used, it should be a project based location so if you switch projects it remembers the last location you rendered to for that project.
Warren Heaton
Are you thinking that in addition to next to media and a user specified location that we should have a choice like “Same as Project” that we see over in the Scratch Disk settings?
If so, I like this idea!
I upvoted it.
