Help with error: "Adobe Acrobat does not allow connection to:"
  • November 8, 2019
  • 44215 views
I have both Adobe Acrobat DC Pro and Adobe Reader DC installed on my laptop. It is necessary because I am slowly learning that what works in the one does not always work in the other, especially when developing forms and interactive PDF's.
At the moment, the error message: "Adobe Acrobat does not allow connection to:" is driving me nuts. I build a a document sveral times a month with hyperlinks to servers on our local network. The hyperlinks work perfectly in Adobe Acrobat Pro DC, but not in Adobe Reader DC. I have checked the "Preferences" settings, and they are identical.
Foxit Reader and Nuance PowerPDF also allow the hyperlinks to work perfectly. Any advice or solutions would be appreciated. I need the hyperlinks to work, and if Adobe Reader doesn't do it then I must recommend that my organisation switch to a different solution.
Correct answer Prasanth_IRPA_Dev
Thanks Amal,
I reset the Acrobat preferences using the 'Manual' method from that link, tried again and get the below error:
Security Block
<URL>
I then closed Adobe, ran the 'repair' option and tried again and had the same error.
Dougal
Hello Team, I've faced the same ERROR. Here you go Edit > Preferences > Trust Manager > Click on Change Settings, Over there you can see the Web sites that are blocked, Just remove the blocked ones
Thanks
Prasanth
Amal.
Hi there,
We are sorry for the trouble. As described above, you are getting the error 'Adobe Acrobat does not allow connection to' while opening the PDF in Adobe Acrobat Reader DC.
Would you mind sharing some more details for a better understanding:
Make sure you have the latest version 19.21.20049 of Adobe Acrobat/Reader DC. Go to Help > Check for Updates. For more details you may please refer to the link- https://www.adobe.com/devnet-docs/acrobatetk/tools/ReleaseNotesDC/index.html
For testing purpose, please try to turn off the protected view. Go to Edit > Preferences > Enhanced Security > Turn Off the protected view and Uncheck the Enhanced security > Click OK and restart the application and check.
Note: Please turn On the security after testing, irrespective of the result as it may cause security risks.
If it works, please refer to the help article (https://helpx.adobe.com/acrobat/kb/protected-mode-troubleshooting-reader.html)
You may also try the steps provided in the help article: https://helpx.adobe.com/in/acrobat/using/allow-or-block-links-internet.html
Let us know how it goes
Regards
Amal
I have tried all the above preference options, as well as whitlisting in the appropriate areas within the preferences, and have the latest Adobe Reader version (2023.006.20380 (64-bit), continuous update) but have the same issue with a custom-type URL.
Other PDF readers prompt the user asking them if they want to open the URL, however no option within Adobe seems to allow this.
Is this something deliberate within Adobe now, or is that something that might be fixed?
Thank you.
Amal.
Hi there
What happens when you try to open the hyperlinks in Acrobat Reader? Do you get any error message? If yes please share the screenshot of the same for more clarity.
Also try to repair the installation from the help menu (Win Only) and see if that works.
You may also try to reset the Acrobat preferences as described here https://community.adobe.com/t5/acrobat-discussions/how-to-reset-acrobat-preference-settings-to-default/td-p/4792082
Let us know how it goes.
~Amal
