Oct 27, 2026 1:36 PM UTC
My read out laud option is not working instead it is asking me to enable text to speech engine, I have tried every possible way but I do not know how to enable it, so that it will start to read the text again laud. Please help me 🙏🙏
I actually like the abode reader app to read the text out laud to me. Earlier it was functioning properly, but now when I select the text and click on the read out laud option it is not reading it instead it is showing me that i need to enable the text to speech engine in order to listen to the text. I have tried many ways to find that option but I cannot find it. So, please suggest me how can i again enable the read out laud function on my app.
    Oct 28, 2026 10:39 PM UTC
    Hi, I use Android (Google pixel 9) and yes Adobe is the most updated version. I have to uninstall and reinstall it several times to make it work. It buffers like this all the time and does nothing. I did enable all the speech to text functions on my phone.
    Anand Sri Bhattacharya
    Oct 28, 2026 11:59 PM UTC
    Thanks for the details ​@subia98321927
    This has been reported to the Engineering for further investigation.
    We’ll share an update once the fix is available.
    Anand Sri.
    Amal Jaiswal
    Oct 28, 2026 11:11 AM UTC
    Hi ​@Merry_impression3088  ​@subia98321927
    ++ Adding to the discussion
    Also, try updating the app to the latest version available on the App/Play Store and reboot the device once and see if that works.
    Let us know how it goes.
    Regards
    Amal
    Oct 27, 2026 8:47 PM UTC
    Hello ​@subia98321927
    I hope you are doing well, and thanks for reaching out. Sorry for the trouble you had.
    A similar issue has already been reported to the product team, and they are investigating and fixing the issue.
    Could you please share more details to assist with the investigation?
    • Are you using an Android or an iOS device? What is the version?
    • What version of the Acrobat Reader app is installed?
    • Can you provide a screenshot of the error message you receive when using the Read Aloud feature?
    We’re here to help, just need more info.
    Anand Sri.
    Oct 27, 2026 2:12 PM UTC
    It is doing the same for me, on and off for the past few days. Adobe, could you fix that please? It is getting very annoying 😭
