Need To Place A Check Mark In A Box Based On Calculated Fields
  • October 28, 2021
  • 494 views
This is my first post and I'm just starting out so please excuse my lack of knowledge. I can't figure out how to place a check mark in one of two fields automatically based on a calculated value compared to a range value. Any help is highly appreciated!
I 'm still trying to make this work and feel I'm close but still not there.
I can blank out the PASS field if a check mark is in the FAIL field but if I try to then add the script to blank out the FAIL field, it all stops working.
//PASS FIELD//
var VarianceRow1_2 = Number(this.getField("VarianceRow1_2").value);
if (VarianceRow1_2>-1.0 && VarianceRow1_2<1.0) event.value = resetForm(["FAILRow1_2"]);
if (VarianceRow1_2>=-1.0 && VarianceRow1_2<=1.0) event.value = "✔";
//FAIL FIELD//
if (VarianceRow1_2<-1.0 || VarianceRow1_2>1.0) event.value = resetForm(["PASSRow1_2"]);
if (VarianceRow1_2<-1.0 || VarianceRow1_2>1.0) event.value = "✔";
I finally stumbled my way to the correct script. Whew! Learning by trial and error can be rough.
//PASS FIELD//
else event.value = resetForm(["PASSRow1_2"])
//FAIL FIELD//
else event.value = resetForm(["FAILRow1_2"])
try67
Thank you TRY67. Especially for the String.fromCharCode(10004). Using a check mark was causing problems. I had no clue how to fix it. I guess since I'm completely new to Java scripts, I'll find a reference list of commands that can be used. Any suggestions?
Thanks again for your help!
Steve
That list is enormous. If you need help with something specific let us know and we'll help you out...
