Help With Poor Quality Photo
  • October 21, 2018
  • 328 views
Hi Support
Today I bought a photo which I want to print to a canvas 120x90mm. Unfortunately, the quality of the photo is too poor, even though it is sold as XL 300dpi. The download is File: #171347227. The file is no good to me now.
Kind regards
Henriette
    Correct answer Sheena Kaul
    The file looks to be fine. It's 4500 X 300 pixels and the quality looks decent.
    The size probably that you're trying to print is quite large and you'll be requiring a larger file to avoid pixelation.
    I'd suggest you probably check with your printer the minimum file size required to print such a canvas and then license a file accordingly.
    Sheena Kaul
    Hi Henriette,
    I apologize for the experience with the file that you downloaded.
    Let me get this file checked and update you. Kindly allow me sometime.
    Sheena
    October 21, 2018
    Sorry 1200x900 mm
    Sheena Kaul
    Sheena KaulCorrect answer
