Clarification of technical issues on these images.
  • August 8, 2021
  • 1155 views
Hi
Can I have some more advice please? These images have been rejected on technical issues too. I'm thinking it is focus/sharpness? The Statue's face looks focused on thee chin, but not the eyes? The hand is focused on the thumb but depth of field is too shallow so fingers are not clear?
Thank you in advance for your time and patience!
Correct answer Nancy OShea
1. Adobe Stock customers expect the highest visual and technical quality for use in their own projects.
2. Nobody buys B&W images.  Adobe Stock customers want full color with neutral white balance.  They can adjust color to their project's specifications in Photoshop or Lightroom, if required.
See links below:
Nancy OShea
Nancy OSheaCommunity ExpertCorrect answer
See links below:
Jill_C
In addition to the halo that Ralph has pointed out, I think the forearms in the first image are underexposed. The second image seems to have almost nothing in focus, and the finger, or whatever it is, on the far right edge of the frame has been chopped off. Adobe Stock does not accept black and white conversions, per the instructions they've issued to Stock Contributors. The assumption is that Buyers can do that themselves if that's what they're looking for.  Even if both images were NOT rejected for Technical Issues, they might have been rejected for Intellectual Property violations since a Property Release might required for these artworks.
Jill C., Forum Volunteer
RALPH_L
Zoom in on both photos to 150%. On the first you can see a blue halo between the sphere and her forehead. The second photo has artifacts.
PeteSW64Author
Thank you all for your feedback.
What causes the blue halo?
Many Thanks
PeteSW64Author
The blue halo is chromatic aberration. It's also present here:
Why should a picture “taken on a Sony Alpha a57 at ISO 640 1/320 at f6.3 with minimal post-processing” cause no problems?
First ISO640 causes a lot of noise but 1/320 suggest that you would have reserves. If you did not shoot raw, the JPEG conversion was not exactly praised in the tests. There is possibility to use a digital zoom, you should never use that. Chromatic aberration needs post-processing. The contrast level and the exposure is not good.
And you are right: you need absolutely put the focus on the correct places. With portrait, the eyes are to be aimed at.
Additionally, I agree with @Jill_C on the IP problem.
If you are new to stock, you should consider these resources: https://helpx.adobe.com/stock/contributor/tutorials.html
Please read the contributor user manual for more information on Adobe stock contributions: https://helpx.adobe.com/stock/contributor/user-guide.html
See here for rejection reasons: https://helpx.adobe.com/stock/contributor/help/reasons-for-content-rejection.html
and especially quality and technical issues: https://helpx.adobe.com/stock/contributor/help/quality-and-technical-issues.html
Hi
Ok thank you. I know the higher ISO gives noisy images on the a57 but I though ISO 640 was relatively ok. It was also taken with a zoom. I did not know about the post processing for CA. Most of my photographic knowledge is from the old 35mm days and post processing is a new thing for me.
One of the problems I am experiencing is that my monitor is a bit old and small and not easy to see these issues. Sure I can zoom in, but not sure what to expect at what level of magnification.
I will study the tutorials.
Thank you
