Feb 11, 2025 6:34 AM UTC
Hello, help to understand why it was rejected? Cause Quality problems. All were in AI generated png
문제를 알려주세요
Jill_C
Feb 11, 2025 4:54 PM UTC
Zoom in 100-200% and inspect every area of your images before uploading. AI frequently messes up chair legs and table legs. Here are a few example of AI drawing errors. There are others.
Jill C., Forum Volunteer
daniellei4510
Feb 11, 2025 3:51 PM UTC
While it's certainly possible for AI to do complex architecture (interiors and exteriors), one needs lots of luck or a very strong background in editing to fix errors.
Abambo
Feb 11, 2025 1:03 PM UTC
You do not need to look very accurately to see multiple rendering errors.
RALPH_L
Feb 11, 2025 7:48 AM UTC
In the first image, look at the legs on the white chairs on the left side of the table.
yamato713108855
Feb 11, 2025 7:20 AM UTC
1.There is a shadow in the groove in the ceiling.
2.The plants and chairs in the back have unnatural shapes.
3.The building's pillars are warped.
There may be more if you look closely.
