help to reject my photos(quality issue rejection)
  • February 6, 2025
  • 407 views
help to find out why my images rejected
thank you for your help.
it is ai generated images
Correct answer Jill_C
Face cream doesn't look like that either... this looks like putty
Abambo
You need to sharpen your assets after upscaling. This, however, needs to be done carefully, to keep the look naturally.
A good upscaler takes care of that.
Jill_C
Jill_CCommunity ExpertCorrect answer
Jill C., Forum Volunteer
daniellei4510
They seem to lack sharpness overall, the woman looks a bit overexposed, and there's a lack of detail in the hair.
Adobe Community Expert | If you can't fix it, hide it; if you can't hide it, delete it.
thanks for your advice! I passed in a day after applying your advice.
daniellei4510
Glad to be of help.
