nayon99
Apr 2, 2026 11:57 PM UTC
make those using AI and then make vector Adobe illustrator but when i uploaded it's rejected because of quality issues. And bottom 2 images are fully design by Adobe illustrato but same problem here
    N8.
    Apr 3, 2026 7:36 AM UTC
    Hey ​@nayon99
    Just because they are vector doesn’t mean that there are not issues.
    Creating an image using one of the models is great start. We still need to take a bit of time to clean up the lines and text. As ​@daniellei4510  pointed out the windows look bubbly and not uniform.
    Regarding the images with text: in general I stay away from adding text. Let the consumer add their own message and content.
    The background looks lovely… however, some of the shapes are not exactly crisp where as the other shapes are crisp. Consistency matters.
    Cheers
    Nate
    daniellei4510
    Apr 3, 2026 1:30 AM UTC
    I can’t speak of the other two image since I’m not sure what the content is about, but here are a couple of things the moderator might have objected to.
    nayon99
    nayon99Author
    Apr 3, 2026 4:57 AM UTC
    Thank you
    Nancy OShea
    Apr 3, 2026 12:52 AM UTC
    Do to cultural & language differences, I’m unable to judge the bottom 2 images. Sorry.
    Did you follow the Vector Requirements?
    https://helpx.adobe.com/stock/contributor/help/vector-requirements.html
    Cosmic Studio
    Apr 3, 2026 12:12 AM UTC
    On the first image, there appears to be an anatomical error on the hand holding the key, just below the little finger.
    I could be mistaken, but all the files also seem to need a bit more sharpness or smoother edges, as their contours appear slightly jagged.
    I hope this helps!
    Cosmic Studio
    Apr 3, 2026 12:19 AM UTC
    On the second image, the percussion instrument could benefit from a bit more finishing, such as adding shadows. To me, it currently looks like the instrument was added as a PNG on top of the image.🤔
    nayon99
    nayon99Author
    Apr 3, 2026 12:25 AM UTC
    It's totaly vector
