selcuk c photo
My photo was rejected due to quality issues. Where is the quality problem? Can you help me?
Bu 3 fotoğrafım ve buna benzer bazı fotoğraflarım kalite sorunları nedeniyle reddedildi. Gününde ciddi bir sorun göremedim. Sorunları işaretleyebilir misiniz? Yardımlarınız için teşekkürler
Ricky336
The third photo isn't actually B&W, just not exposed well so it looks B&W.
@selcuk c photo shooting into the light as you have done in the palm photo will not give good colours, especially as it is overcast, the light is very flat; it is not a good idea to take photos directly into the sky, especially if it is overcast.
Also, you have light fall off = the corners are dark, due to the nature of the lens.
Unfortunately, the photos you have uploaded, won't pass Adobe's criteria.
Abambo
Your first:
The small sensor of the drone did introduce artefacts (cloud) in the picture because the post-production tried to compensate for the physical limitations of the sensor. You see the same limitations in your second post.
You should always edit out markers (arrow) on any  element, as those will constitute an IP violation. This picture is beyond repair, however.
Your second:
That picture has obviously difficulties with the small sensor size, creating quality issues, that result in flat colours and details:
In addition, you have compression artefacts:
And that white border at the sky limits also constitutes a problem.
The whole picture should have more contrast.
The palms:
Look at your histogram:
Blacks are missing and whites and part of the highlights are missing. This is a serious exposure issue.
If you look at your subject, you see that it is out of focus and noisy:
(out of focus in not corrigible)
You will need to check your assets at 100% before submitting. Checking the picture on a small screen will not reveal the issues.
If you are new to stock, you should consider these resources: https://helpx.adobe.com/stock/contributor/tutorials.html
Please read the contributor user manual for more information on Adobe stock contributions: https://helpx.adobe.com/stock/contributor/user-guide.html
See here for rejection reasons: https://helpx.adobe.com/stock/contributor/help/reasons-for-content-rejection.html
and especially quality and technical issues: https://helpx.adobe.com/stock/contributor/help/quality-and-technical-issues.html
jacquelingphoto2017
Hi @selcuk c photo ,
The photos are nice but has several technical issues. They are all underexposed.
The first photo has detail loss typical of camera with small sensors. It also displays chromatic noise when zoomed.
The second photos also displays lost details.
The third photo is extremely noisy, has motion blur and displays incorrect colors.
Best wishes
Jacquelin
Jill_C
The first image has some visible logos which should have earned an IP rejection.
The second image has noise in the sky.
The third image is a black and white conversion which Adobe does not allow.
Jill C., Forum Volunteer
