Nancy OShea
I understand that, but problem is technical quality, or non-commercial photos? Its not equal...
Jill_C
Moderators can only choose one rejection reason on each asset, presumably the first one they notice, though there may be multiple reasons to reject it. If focus problems are the first thing they notice, they will select "quality issues". But there could also be IP issues or lack of commercial appeal or other issues.
Jill C., Forum Volunteer
Jill_C
DSC_9286.jpg - these look delicious, but you've cropped in too close, cutting off part of the subject matter. Also slightly underexposed according to the histogram.
DSC_7888-Улучшено-NR.jpg - underexposed and depth of field is too shallow, resulting in much of the image being out of focus.
How about this shots? Same history...
Jill_C
DSC_7637-Улучшено-NR.jpg - underexposed, cropped too close (or should have been shot in landscape orientation), many unfocused areas
DSC_7654-Exposure.jpg - there are some out of focus areas, probably due to depth of field being too shallow
DSC_7923-Улучшено-NR-Exposure.jpg - zoom in to 100-200% and you'll see that most of the purple flowers are not in focus; the sun flare might have been a problem too
