[Quality Issues] is it because they think I've applied filter?
  • December 27, 2024
  • 196 views
here is the image
Correct answer RALPH_L
There is a sensor spot in the sky. The sky has some noise and the shadows are two dark.
Also, if you lighten the photo, you can read the trademark "Mercury" and can see a number on the boat.
Abambo
May I ad: You also have a lot of noise.
And just for the record: I've seen at least 3 other sensor dust spots, so I really recommend that you perform (or let perform) a sensor cleaning.
daniellei4510
Having the camera lens (cell phone lens?) pointed directly at the sun caused underexposure and a loss of detail in the main subject areas.
Adobe Community Expert | If you can't fix it, hide it; if you can't hide it, delete it.
KicoohhAuthor
its my edit that I turned up the contrast too much
RALPH_L
RALPH_LCommunity ExpertCorrect answer
KicoohhAuthor
thank you for pointing out, hopefully my update will be accepted
