Quality issues rejection for transparent background images done in photoroom.com
  • January 30, 2025
  • 489 views
Please guide me regarding why the attached images were rejected. I have removed their background in photoroom.com (instant background remover). The ones with background were not rejected. Please tell me the issue.
Abambo
Your program is working quite nicely, much better than expected. But still, there are flaws that would need manual rework.
Just one example:
When you look at the same image a little bit down, you have a "worm" sticking out (1). I suspect that being a leftover from a plate under the bowl. If you check the red line (my addition), there should not be "jagged" corners, but smooth lines. When a buyer will put this plate on his background, the jagged lines (which suggest an bad cutout line) may cause issues.
Jill_C
It's best to view transparencies on a black background to confirm whether there are any edge cutout issues.
Jill C., Forum Volunteer
oh. Thanks for the reply Jill. Got it. Can u suggest a good free open source website that gives correct transparent background image?
daniellei4510
There is no such thing. It has to be done by hand using the pen tool in Adobe Photoshop.
Adobe Community Expert | If you can't fix it, hide it; if you can't hide it, delete it.
Hi purpleshine - it's hard to tell when it's not the original images. But at least in image #3 there's an odd point sticking out from the bowl. But sadly enough there are so manu flaws in the images that in my view they shoud not have been accepted. Are you submitting the same images with and without background?
yes. with background images have been accepted. but can u pl explain what are the many flaws?
Abambo
quote
By @purpleshine.s.26
Submitting the images twice, once with and once without background is considered as spam and will ultimately lead to you getting banned. You should only submit the PNG files with backgrounds removed.
